Hi all
Question for the day.
I currently run Simex JT2's 33x11.5x15 was looking at going to Simex 35x10.5x15 Centipede's.
Reading up on all the info,(dia measurements from Simex) I came across the interesting fact that the 35 is only 14mm greater in diameter than my 33's and in fact the 33's measure out to 34.25" v the 35's 34.75" mmmmmmm.
Bearing in mind it looks like I will not gain any diameter to talk off, is the Centipede's performace that much better than the JT2's.
Personal observation is not, but, can only compare how I go compared to 35 Cent shod wagons (different makes)
would like to hear others opinion.(especailly if you have run both type of tyre on the same wagon)
Rat
SIMEX
Hey Rat,
I have the 34X10.5 JT2's and I have driven rangies with the 35 ET's.
It goes without saying that these are both great tyres.
When it comes to traction and mud flinging ability I believe the ET's do have an edge over the JT2's. I think it is simply down to the substantial voids in the ET which can move a lot of earth.
Downside is that they are directional and so you have to be a little clairvoyant to know which side you are going to puncture...
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
Hey Rat, What rims are you running, if steel have a look at getting them reversed. With an additional 50mm offset you might find you will get a lot of lock back, even with 35's. I have 255x85x16 on reversed disco rim's and still have plenty of clearance to trailing arms with out the stops adjusted at all.
Just a thought,
Kevin
Just a thought,
Kevin
Backspacing
100mm for 8 inch rims
75mm for 7 inch
75mm for 7 inch
- Alinney90@gmail.com
- Driver/Navigator
Re: SIMEX
Hi, where do u get your simex 33x11.5x15's from i am in auckland and need a new set ??
