lowering diff if possible?
For all Suzuki related topics
amateur
Post by amateur »
hey i saw in the cheap suzuki lift forum someone said they were going to lower their diff to help their cv's is this possible and if it is... is it as hard as it sounds?
cheers,
Luke
lneil
Re: lowering diff if possible?
Post by lneil »
You really only need to lower the front diff on a vitara/escudo if you're going over about two inches suspension lift. It's not too hard, but you need to get good bracketry made up accurately.
truck-fixer
Post by truck-fixer »
Yeah I had to do it to the scud after its 3" suspension lift. Took it to our engineer at work, told him what I had to do. He had the Calmini Brackets modified within a couple of hours and they fitted perfectly. Havn't had an issue with CV's since.
Weemsy
Post by Weemsy »
im getting some lowering brackets from the uk.
i couldnt get calmini brackets seperate so my sister is bringing them with her in a week or so and reece @ de-ranged engineering is going to make something similar when they get here, so might be worth getting in touch with him in a few weeks.
his name on here is DE-RANGED if you want to pm him??
weemsy
Heath
Post by Heath »
<cue shocked look>"what breach copy right! How could you?" :?
Count me in for a set for later on. :twisted:
lneil
Post by lneil »
Me too, if I ever get the daughter's trucks finished so I can start on my own.
Hell Weemsy, between you and De-Ranged you're going to have the 'Zuk after-market sown up by the end of the year.
I can just see it, I'm going to be broke forever!!
Weemsy
Post by Weemsy »
hahaha yep, were trying to. well he is, i just stand around talking sh1te!!!! :lol:
Heath
Post by Heath »
Ahh. You have the same skill set as me then.
Return to “Suzuki”
