my starter motor seems to have pooped it self over the weekend, It turns the motor over, but only ones or twice, the battery is low on power to, so we tryed to jump start it, but that didn't work the leads just got hot and that was it.
Im going to try the vans battery tonight but if that doesn't wotk it's most likely to be the starter motor.
So yea if anyone has a starter motor for a 2lt ill br keen to buy it if the problem is not the battery
Cheers.
!WANTED! 2lt starter motor
Re: !WANTED! 2lt starter motor
If you do end up needing one and you can't find one locally i've got one I can sell ya. PM me if you need it.
86-surf wrote:my starter motor seems to have pooped it self over the weekend, It turns the motor over, but only ones or twice, the battery is low on power to, so we tryed to jump start it, but that didn't work the leads just got hot and that was it.
Cheers.
I should have one it you get stuck
- skid
- Tyre Man
take it out and clean it and rebuild it, all hori like and it should go for a while yet
take it out, undo the 3 screws on the plate on the back of the solenoid. inside should be a piston and 2 contacts. replace the contacts or just sand them up a bit, clean the contact surface on the piston and she should be all good. test it before you chuck it back in - hook up a battery to it - positive to the main terminal, earth to the mounting flange, then touch a small wire to the solenoid terminal.
if not, i've got one too.
my lux starter was dead, had seized bearings and dodgy contacts, just gave it a rebuild and now its mint no need to replace just try rebuilding it. plug the breather holes too, it will stop crap getting in,the auto sparkys reckoned the holes were useless anyways
well the problem is a stuffed battery and a even worse problem... the altinator (spelling), witch pisses me off because i don't have $$$ to buy or get it rebuilt.
86-surf wrote:well the problem is a stuffed battery and a even worse problem... the altinator (spelling), witch pisses me off because i don't have $$$ to buy or get it rebuilt.
I prob have one you can have
- skid
- Tyre Man
does anyone know if a 2LT starter motor is the same as a 2L starter motor, or 2LTE or 3L
- evolution02
skid wrote:does anyone know if a 2LT starter motor is the same as a 2L starter motor, or 2LTE or 3L
Yeah mate all L series engines starter motors are interchangable. There are slight differences through the years but all will work fine with each other. 1KZ starters are different
