rim offset
cruza
rim offset
Post by cruza »
Rim offset. How/where is this measured from? . Mucking around today with old set of 15' white spokes. Got probs with clearance on the brake calipers on the back of my 80 series, Had heard of the, 5 mins with the grinder fix.... .Thought I'd price some 16' white spokes . Not sure what offset?. like to get the same offset as my 15' ones , not sure where to measure from?
Re: rim offset
tyre shop should know what offset to supply
otherwise I can go into detail on how and where to measure
aroma
Re: rim offset
Post by aroma »
Hi
have a set of white spokes 15" here that should fit what part of nz you u i'm chch
warren 9421069 0274913440 ph or txt ok
lneil
Re: rim offset
Post by lneil »
Offset is measured from the midpoint of the rim-width, to the rear (mounting) face. Dead-centre is zero offset, positive offset is where the mounting face is spaced towards the outside of the rim (i.e rim sits further in towards the vehicle centreline), negative offset is when the mounting face sits inwards in the rim so that the rim itself is spaced out from the vehicle.
eg. a -15mm offset on a wheel will have each wheel sitting 15mm further out from the vehicle than a zero offset.
Clear as mud?
furnace
Re: rim offset
Post by furnace »
cruza wrote:Rim offset. How/where is this measured from? . Mucking around today with old set of 15' white spokes. Got probs with clearance on the brake calipers on the back of my 80 series, Had heard of the, 5 mins with the grinder fix.... .Thought I'd price some 16' white spokes . Not sure what offset?. like to get the same offset as my 15' ones , not sure where to measure from?
It depends on the width,15x8 should be negtive 24 and 15x10 negtive 44,have just done my cruiser with 15x10
Re: rim offset
hes looking at 16s and 15s have lots of variations due to lots of brands of wheels
can I ask why you want 16s
4WDbits
Re: rim offset
Post by 4WDbits »
Have a look at http://www.4wdbits.co.nz/rimmeasurements.aspx
If you have a post 1992 cruiser you should have 16 inch rims to clear the calipers. Look for approx -19 to -24 offset.
cruza
Re: rim offset
Post by cruza »
Rims hit brake caliper on rear , not by much, thought 16" would give the clearance needed. fronts ok.
cruza
Re: rim offset
Post by cruza »
[quote="4WDbits"]Have a look at http://www.4wdbits.co.nz/rimmeasurements.aspx
If you have a post 1992 cruiser you should have 16 inch rims to clear the calipers. Look for approx -19 to -24 offset.[/quote
thanks
Return to “Tyres”
