Commodore 3.8 HELP!!
Hey guys.
HELP PLEASE!!!!!
Ive got a holden 3.8v6 from a VR commodore in my hilux.
A weekend or two a go it stoped on me while throwing it around in the mud.
At the start it would idle fine and rev fine but when under load wouldnt rev atal and then it stoped and wont start any more.
Has no spark or injector pulse so replaced crank sensor and still no go.
Makes me think it might be ecu but how could i diagnose this without buying one and trying it?
Any other posabilitys that it might me? Anyone had similar problems before?
Does anyone have a vr engine ecu in chch that i could maybe borow to plug in to see if its the problem.
Any help would be great.
Thanks
Nick
HELP PLEASE!!!!!
Thanks
Nick
027 337 0579
- rangimotors
Re: Comidore 3.8 HELP!!
commodore
- rangimotors
Re: Commodore 3.8 HELP!!
ha ha if all else fails ill give you the lada
I can get the ecu out of my mates monster suzuki thing hes bilding and hook that up and see if thats the problem its a VN ecu i guess there the same
I own a POS toyota with nissan bits in it.Basicly lives in the shed
Could always visit a carsales and take one for a test drive
Has it got the factory ecu or an aftermarket one?
Holden ecu's are super simple for those who know their way around them. (the v6 I believe is a 1 wire hook up). There is a holden wrecker in Gasson st who may be able to help you out with another (or loaner) box
cruzerboy wrote:I can get the ecu out of my mates monster suzuki thing hes bilding and hook that up and see if thats the problem its a VN ecu i guess there the same
Thanks mate, think series two vn engines are the same but the early series one is diferant. Could you find out what its got please.
027 337 0579
rokhound wrote:Has it got the factory ecu or an aftermarket one?
Hey, just factory comp but peoplethat wired it didnt add the diagnostic plug so cant scan it, thanks ill give them a try.
027 337 0579
H2OLOVA wrote:Could always visit a carsales and take one for a test drive
haha i like your thinking, maybe ill borow a 5.7 v8 one and swap the lot
027 337 0579
hay nick stop in to work we have a ecu
scott gibson
had a look at my mates one today its a series 1
radar21 wrote:hay nick stop in to work we have a ecu
Ledgend, will do in the morning mate, thanks
027 337 0579
cruzerboy wrote:had a look at my mates one today its a series 1
Cool thanks anyway mate
027 337 0579
the plug on the module gives alot of trouble two that controls injector pules to so check that out to
scott gibson
Ok where would i find that normaly?
Are you able to test ecus at your work?
027 337 0579
bottom of the coil pack at the end its got a 8mm bolt in it check that its got power and that its tight and that the plugs not bent nah we send them to nelson a place called anything electronic
scott gibson
do they call that the DFI unit?
i bought a coil and a DFI unit of trademe but it apares hes done a runner with my parts and money
027 337 0579
yep direct fire injection the dear part of it all .that sucks that the guy made off with your money
scott gibson
IGNITION sorry not injection
im away with the faires at the mowe
scott gibson
Tryed coil pack and dfi today but still no go, one i used is from a vn series one but was told it would work fine so hoping that not still my problem, takes me back to the ecu now tho. hope i can find one to borow and try if that fails ill admit defeat and give it to someone thats smarted than me with auto sparky shit.
027 337 0579
COMILUX wrote:Tryed coil pack and rdi today but still no go, one i used is from a vn series one but was told it would work fine so hoping that not still my problem, takes me back to the ecu now tho. hope i can find one to borow and try if that fails ill admit defeat and give it to someone thats smarted than me with auto sparky shit.
i was gonna say coil pack as well.... Nailz on here had a RX7 with a 3.8 which developed similar syptoms, and it was coil pack, turned out ants had made a home in it....
but if you swapped coil packs then obviously not that.
rangimotors wrote:ha ha if all else fails ill give you the lada
Yeah go the mighty Lada
