80 series suspension
will a 2inch lift be enough to run 33 inch tyres? . Still want to get the truck in the garage !! . Its my new truck just sold the old 70 series and want to run the 33's rims which were on that.
- skid
- Tyre Man
Re: 80 series suspension
will run 33s on standard suspension
I did exactly the same thing as you, bought an 80 and put the 33s off my BJ74 onto it.
cruza wrote:will a 2inch lift be enough to run 33 inch tyres? . Still want to get the truck in the garage !! . Its my new truck just sold the old 70 series and want to run the 33's rims which were on that.
Be a good as with 2" lift and 33's,i have a 3" lift and now have 35's on mine they seem to be fine
- Andrew1706
Is there much that needs to be done with a 3" lift? Castor correction? Brakelines? Spacers?
Andrew1706 wrote:Is there much that needs to be done with a 3" lift? Castor correction? Brakelines? Spacers?
It wasn't a problem at all,casters needed to be done,brake lines were fine,i think 3" is about as far as you can go without having to do to many mod's..i put old man emu suspension through mine the ony problem i had was the shocks they sent for the 3" were to long allowing the springs to be loose when fully extended so i put in the shocks for the 2" lift which fixed the problem
- skid
- Tyre Man
sorry to thread jack, but it may be useful.
of those of you who have given your 80 a lift, did you find it raised the back slightly higher than the front and if so , did you put coil spacers in or anything like that.
I only ask coz, I've seen a few lifted 80s that are slightly higher in the arse.
skid wrote:sorry to thread jack, but it may be useful.
Yes that does seem to be the case but that suited me fine as i tow a 25'ft caravan with mine,plus a load of gear on the back,i'm going to put poly air bags on mine in the near future to help sag
Would like to here how these go [ poly airbags ]and if any hassle...may start another thread on this
- skid
- Tyre Man
Pm petefj40, he installed some on his 40
- Andrew1706
My 80 is on standard suspension and the arse is a lot higher then the front but that's how they are, load bearing capabilities - towing etc.
Went and got a price for 2" lift kit today (ome) $1280, Sound about right? What else is there, efs looks to have similar price, but haven't really heard of them.
cruza wrote:Went and got a price for 2" lift kit today (ome) $1280, Sound about right? What else is there, efs looks to have similar price, but haven't really heard of them.
Bloody hell thats a lot of money. Is that a suspension lift or body
NO one remembers who comes 2nd....!
gazza wrote:cruza wrote:Went and got a price for 2" lift kit today (ome) $1280, Sound about right? What else is there, efs looks to have similar price, but haven't really heard of them.
Bloody hell thats a lot of money. Is that a suspension lift or bodywhat does it include???
Yes that would be about right,i think i paid about $1400 for mine [ 3" suspension lift ]
I do like the OME Stuff they do work well
holy crap I'm in for a shock. Picked up 2" ome lift kit. looked at std springs and at ome springs , ome looks double the length, using 850/860 combo. That 7 inches clearance in the garage I had , has got me worried. Also a ques . Does "b" springs( which is slightly longer ) go on the passaenger side? no instructions, but guessing our road camber this is the case.
cruza wrote:holy crap I'm in for a shock. Picked up 2" ome lift kit. looked at std springs and at ome springs , ome looks double the length, using 850/860 combo. That 7 inches clearance in the garage I had , has got me worried. Also a ques . Does "b" springs( which is slightly longer ) go on the passaenger side? no instructions, but guessing our road camber this is the case.
Yes B is passenger side
- skid
- Tyre Man
badnuz wrote:cruza wrote:holy crap I'm in for a shock. Picked up 2" ome lift kit. looked at std springs and at ome springs , ome looks double the length, using 850/860 combo. That 7 inches clearance in the garage I had , has got me worried. Also a ques . Does "b" springs( which is slightly longer ) go on the passaenger side? no instructions, but guessing our road camber this is the case.
B must stand for bloody bleating bitch
it would of in my case anyway
skid wrote:badnuz wrote:cruza wrote:holy crap I'm in for a shock. Picked up 2" ome lift kit. looked at std springs and at ome springs , ome looks double the length, using 850/860 combo. That 7 inches clearance in the garage I had , has got me worried. Also a ques . Does "b" springs( which is slightly longer ) go on the passaenger side? no instructions, but guessing our road camber this is the case.
