Range Rover Sport Rock Climbing
Re: Range Rover Sport Rock Climbing
Impressive.
NO one remembers who comes 2nd....!
A first I thought there was some clever camera angle work going on...
But then when the vehicle is going back down you can see that although there may be some slight angle on the camera to make it look more impressive, the fact is the trees and person are standing up very close to vertical. The is one flippin steep bit of rock. Very impressive.
theres no way anything would grip at that angle. deff some video trickery
gazza wrote:theres no way anything would grip at that angle. deff some video trickery
Ever been rock climbing in the states?
If you had then you'd have some more belief in the video.
FFFFFFFFFFFFFFFFFFFFFFark that!!!
(021) 02388443
(021) 02388443
- mike
- Last minute Mike
thats normal for a LR, who wants to go for a ride in the POS?
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
that is one very mean clip.....and those trees are still upright
toymota thats stock standard.
Those late rangies have good traction. Clip is impressive. Look at the grass on its way down when the wheel goes past it it is sticking out on an angle not straight up. I think the camera has been used to advantage but regardless its impressive and not sure that I'd be going down it with my cruiser and its brakes!
Yeah there's some angle in the camera but it's very slight. You can tell by the way the range rover starts to slide on the downhill section that it's bloody steep!
I haven't been climbing in the states but I've been climbing on granite in the UK and you wouldn't believe the friction you can get. Still I wouldn't attempt this without a crash helmet, a roll cage and some amazing car insurance that turns a blind eye to stupidity!!
1993 Hilux Surf SSR-G, 2.4L Turbo Diesel, 2L-TE, LN130, 125,000kms and counting.
nah its bollocks.
the angle changes from when the rangie first drives onto the rock and then as it comes back off... i think there has been some very good work done with an editing program on that clip.
its certainly filmed on a steep hunk of rock, but not as steep as it makes out ot be. or the winch rope has been edited out...
I wouldn't be surprised if it was real, just look at the pressures hes running his tyres
Isuzu Mu 3.1TD
pause it at the 27 second mark....
nstg8a wrote:pause it at the 27 second mark....
Ok did that ...
So ...
What are we looking for ??
- cool__bananas
and you can see at about 1.19 the rear suspension lifts out, so it must be real or bloody close to it
A bit of searching finds out this is filmed at Moegatle Lodge in South Africa. (http://www.moegatle-lodge.co.za/Fourbyfour.htm)
There are a few other vids on YouTube of a Discovery 3 doing the same hill (http://www.youtube.com/watch?v=STt7DmJe ... re=related) and a Hilux.
The incline is quoted in a couple of articles (search Moegatle The Rock on Google) as being 45 degrees.
So yes, there is obviously a little bit of extra angle on the camera to make it look more spectacular but this is indeed one hell of a steep bit of rock.
- Bulletproof
dazza85 wrote:nstg8a wrote:pause it at the 27 second mark....
Ok did that ...
So ...
The tussock is 90 degrees to the truck
Never say die, up man and try
Bulletproof wrote:dazza85 wrote:nstg8a wrote:pause it at the 27 second mark....
Ok did that ...
So ...
thats the one.
theres obviously some seriously steep bits, you see it when its on its way down the rear wheels are only just skipping on the top of the dirt, and if the whole clip was real then it would be an impressive ride...
do the sports have the height adjustable suspension? lift the front at the right time, lower the back a bit... makes it look like weight transfer...
nstg8a wrote:thats the one.
Tussock and grass don't grow vertical like trees do. I agree with the exaggerated camera angle, but it's still bloody steep.
Yes the sports have adjustable suspension, but it's all computer controlled. I don't think the computer has a "lie to the camera" mode.
maybe im being a cynical bastard
but...
- mike
- Last minute Mike
its def real. ill take some of you guys up a slope in my one
wait till you see how a 94 disco chassis climbs without the computer traction stuff
1994 Toyota Surf
1994 Toyota Surf
I recon they fiddled with that pic.
petefj40 wrote:I recon they fiddled with that pic.![]()
Looks like they removed the engine too - the front is sitting a bit high now
When you look at it closely it does look for real. yeah not a bad run. Bit slow though.
Ahhh. My 40 would beat it up that hill NO worries.
I'd tell that kid screaming in the back ground to shut up though.
