got one of these for sale.
http://www.trademe.co.nz/Browse/Listing ... =171817153
Mike
4.1 - 2 pinion hilux diff
- mike
- Last minute Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Re: 4.1 - 2 pinion hilux diff
I'll give you a buck for it
Hard to tell from pic - 4cylinder or v6 carrier?
Chopper01 wrote:I'll give you a buck for it![]()
a Buck ..how cheap...ill give ya 10 lol
Leithfield wrote:Hard to tell from pic - 4cylinder or v6 carrier?
its a 2 pin, so to you, a 4cyl
Just a little tech snippet here, the term 4cylinder and v6 carriers came from the US as they never had solid axle hiluxs after 86 and anything 4 cylinder was still a 2 spider diff. the 6's had 4 spiders.
Basically in NZ any ln130s and later had the 4spiders. Dont quote me on that as its just what I understand, so I could be wrong
The easiest way to tell the difference is the number of ribs, a 4cyl has 3 ribs on each side and the V6 has 4 on each side
See here
http://home.4x4wire.com/erik/diffs/3rds.jpg
See here
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Yes, new the old rib count trick but couldn't tell from the pic.
