i am looking for a set of 33 inch tyres for my 70 serise swb landcruiser to use on and off road but dont realy no whats good and whats bad can any one help me
what tyres should i buy??
hi there,
1979 TOYOTA LANDCRUISER CUT DOWN, 1978 swb cruiser, 1989 70 serise swb cruiser
Re: what tyres should i buy??
EDDY wrote:hi there,
Jerry was selling his 33's
- Bulletproof
My 2 cents worth which others will disagree with is.
70 series Cruisers have big diffs and are heavy and you want to use them on the road. This rules out a Cross Ply like the simex or silerstones
I personally would go for a 33x12.5 radial to spread the weight. Before buying one measure it because they vary from 31.5 to33 inch high. You need the maximin height because of the big diff size.
I dont think there is much in the tread pattern. the main thing is low pressure off road . I personally run BFGs because they are reasonably true to size and have 3 plys where most have 2.
Cheers Richard
Never say die, up man and try
if i was going to buy 1 set of tyres for everything on a cruiser it would be maxxis mudzillas
These would be perfect for you; http://www.trademe.co.nz/Browse/Listing ... =171619522
- moonhopper
I have a near new set of savero mud terains that are on my Range rover up for grabs, they are 33x12.5x15 great tyre's. i just want to go to 35"
would these be any good? http://www.trademe.co.nz/Browse/Listing ... =171534478
If its one set of tyres for everything then go for radial mud terrain tyres. Simex and Silverstone are bias ply, they will give a cr_p ride on the ride and wear out quickly. There are lots of muddies in 33, Maxxis have buckshot mudder and bighorn, Wranglers have a good following for some terrains, Nankang, Sumitomo is cheap and worked well in snow, Nankang is cheaper again, Kumho have a couple of treads and ripme has a few listings.
As for tread patterns and preferences everyone you ask will have a different opinion, if you have time go with the local club and see whos tyres work in the local conditions and remember that worn tyres are never as good as something straight from the tyre shop.
- mudlva
hit there what ever you decide make sure they are black round and rubbery its always a good start
yea thats good advice lol
