hi guys and girls, i have a 2.0l v6 two door suzuki escudo 1995, which
on several occasions has taken small amounts of water into the coils,
making the engine to misfire. i have asked around and have been told
that sealing the covers over the coil packs will just trap
condensation, causing the same misfire. anyone have a solution? or a
trick they have done to there truck. any advice much appreciated.
water touchy 2.0 V6 zuk
If you never get stuck, your never trying hard enough
Re: water touchy 2.0 V6 zuk
hi,
i had exactly the same trouble with my v6 just before i sold it.
the only thing i found to cure it is to blow the coils over with compressed air to get as much of the moisture out as possible.
then keep clear with the water blaster and try not to go near deep river crossings
weemsy
weemsy
- cool__bananas
what about cover them in silicone spray the cover them in glade wrap?
ill try silicone spray, dont no about gladwrap it might melt to the engine
