GQ Safari front diff head and front radius arms
Evenign all...
Looking for a cheap front diff head for my Safari, lookin at gettin a locker, however my one has a LOKKA auto locker and will be sellin it as a unit..
any help or offers greatly appreciated
T
T
Re: GQ Safari front diff head
got one at work spare
coxsy wrote:got one at work spare
Hmmmm Really!!! How Muchee????
- Sadam_Husain
- Angry bird
You swapping the auto locker for one of those chinese air lockers tony?
it was given to me a lwb was stolen the front diff bent the garage that did the repairs gave me the spare head from the change, so i got a head, how do we get it to you
Sadam_Husain wrote:You swapping the auto locker for one of those chinese air lockers tony?
Maybe... Maybe not...
coxsy wrote:it was given to me a lwb was stolen the front diff bent the garage that did the repairs gave me the spare head from the change, so i got a head, how do we get it to you
Prob Courier might be the best bet unless someone has contacts???...
I'll check with Brenics who do AK to WN and see what they can do, I might need it dropping off in AK somewhere thats all
I'll get back to you
Tony
cool its sitting in a over strained cardboard box on our storage mazazine
- Sadam_Husain
- Angry bird
Gazza posted something recently about his truckie mate that can do AK WLG stuff for cheap
what about a terrano LSD rear for the front?
- curly12
Jerry wrote:what about a terrano LSD rear for the front?
Jerry,ffs read Tonys post
Also lookng for front radius arms..Need to do castor correction bushes but but would be easier fitting them to a spare set and doing a swap..Cheers..
Oh yea.....Jerry.. FFS
- safaripete
how much for urs with the lokka?
- cool__bananas
cool__bananas wrote:http://72.34.32.141/~snakerac/product_info.php?cPath=3_106_113&products_id=2036&osCsid=2d47f5b30253d62c6610b84745dc7d92
Cough Cough choke choke... at that price i'll buy 2
Unless you have 2 and offering me 1
You'd be better off with dobinson high flex coils, and superior radius arms than the Snake Racing kit
safaripete wrote:how much for urs with the lokka?
Sorry dude.. yoiur 3rd in line.. I already had 2 pm's within 5mins of puttin the post up...i'll keep you in mind tho..
Tony,
You don't want a diff head, you want the complete LWB chassis and pair of diffs that is sitting in my shed and taking up space...seriously, you'll need a spare for your other truck.
Anyway, there's a front diff head here if you want it.
GQTROL wrote:Tony,
Cheers for the offer..Coxys sendin one down for me.. Meant to ask you Coxsy, is it from a Manual or Auto?? I heard the ratio's might be different???
Re: GQ Safari front diff head and front radius arms
4.11
Nizsafari wrote:Also lookng for front radius arms..Need to do castor correction bushes but but would be easier fitting them to a spare set and doing a swap..Cheers..
Oh yea.....Jerry.. FFS![]()
If you want some strong radius arms with castor correction and GU bushes (good for flex), ready to bolt on then try this http://www.4wdbits.co.nz/ProductDetails.aspx?productID=927 You could always keep you stock radius arms and fit drop boxes http://www.4wdbits.co.nz/ProductDetails.aspx?productID=1186, a gearbox cross member trim and bolt on.
Castor correction bushes reduce flex.
4WDbits wrote:Nizsafari wrote:Also lookng for front radius arms..Need to do castor correction bushes but but would be easier fitting them to a spare set and doing a swap..Cheers..
HMMMM $500 for drop boxes... $1500 for radius arms....cheers for the info but i think ill stick with my $132.50 castor correction bushes....
coxsy wrote:4.11
Sweet...
Nizsafari wrote:4WDbits wrote:HMMMM $500 for drop boxes... $1500 for radius arms....cheers for the info but i think ill stick with my $132.50 castor correction bushes....
How much lift have you gone for? Any flex you were going to acheive by fitting new coils will be gone if you use those bushes.
Try grant guy for dropboxes they were about 300 when i bought mine if i remember correctly
MWB V8 Safari Ute
doddzee wrote:Nizsafari wrote:4WDbits wrote:HMMMM $500 for drop boxes... $1500 for radius arms....cheers for the info but i think ill stick with my $132.50 castor correction bushes....
I've got 2in lift with 30mm coil spacers.. I have plenty of flex in the front., I'm not running a comp truck so basically all i want to do is re-allign the front diff to take the strain off the front drive shaft UJ..
