What motor
For all Suzuki related topics
motivated
What motor
Post by motivated »
This is from another post:
>>Is it a vitara or grand vitara ? I know that the vitara has the mazda diesel in them and they ran these in the 626 since about late 80's<<
I'm looking to build something similar to my avatar as a project for my son and I.
My lady has a Vitara (escudo) 1600 and they seem a little under powered for what I want to do (Hilux diffs etc).
Is there a 2lt petrol motor (say mid 80 mazda 626) that will bolt straight up or do I need to go for all Hilux/Isuzu running gear.
I'm also asking as I wish to repower my ladys vehicle.
Also, if you know of a Zuk body doing nothing in the S.I I would be interested in knowing.
Thanks
krawlr
Post by krawlr »
thats an upper hutt rig..............
doddzee
Is Doddgee
Post by doddzee »
Yeah it use to be in upperhutt but he sold it a couple of months ago not sure where it is now.
If you get your gearing sorted the suziki motor will beable to turn 35's, There are quite a few in aussie that run 35's or bigger, have a look at http://www.outerlimits4x4.com there is alot of good info on there.
You can buy low ratio gears for the transfer which will drop the transfer ratio 120% so you can run those big tyres
apex
Post by apex »
That beasty in the photo was running a 2.2 petrol hilux engine that had been re-cammed for better torque. It worked well. If you are running Hilux diffs/Transfer you should be able to run any engine combo up to around 3.0l without any problems. Plenty of v8 hiluxes around so they must be fairly tough.
Return to “Suzuki”
