CTR's new toy
Steve_t647
Re: CTR's new toy
Post by Steve_t647 »
Another vote for the auto work going into the tech section, but I still have no idea how they work :oops:.
Chopper have you measured the length of the boxes? How long is the Holden Auto and duals compared to the original hilux box? Also if you make any oil pickup mods can you document these also, a couple of the holdens that have died that were in 4wds were put down to oil pickup on angles.
Are you thinking of going back to lpg or just get it going first?
doin_it_dirty
Re: CTR's new toy
Post by doin_it_dirty »
nice work, il keep a close eye on this build, as i wana do a comy conversion within the nex 12 months on my 60, and ill be tracking down the likes of yourself to steer me in the right direction for parts and the nohow, im gona look at buying a commodore shortly to drive around for a bit before i rip its guts out for the conv.
keep up the good work and progress updates, you are now officially my guinee pig :D :D :lol:
do it right, do it dirty
Chopper01
Rock God
Re: CTR's new toy
Post by Chopper01 »
Steve_t647 wrote:Another vote for the auto work going into the tech section, but I still have no idea how they work :oops:.
The commy auto is shorter than the toyota gear box so this ment I was able to put the motor a little bit more forward an
d run standard drive shafts with the dual transfers :shock: :shock: :shock:
but anyway I got the motor in the hole on saturday night we had to move the motor forward about 80mm so the throtle body will miss the fire wall , so this ment cutting my low profile cross member but I could also lift the transfers and auto up another 60mm also I had to make new engine moutns as the commy ones wont work. so we will wire it up tonight :twisted: :twisted: :twisted: :twisted:
Chopper01
Rock God
Re: CTR's new toy
Post by Chopper01 »
well we got the motor running last night thanks to mike for his help. it ran a bit rough to start with but once I replaced a broken spark plug she ran mint :mrgreen: :mrgreen: :mrgreen: :mrgreen:
all I have to do is modify the sump to miss the high steer arms :roll: :roll: but got cracking on that tonight and removed sump and hacked out the part I need for the clearence for the arms and will fold up some steel for the bit I'll cut out of the sump and also the bit for moveing the sump back to hold more oil arround the pick up
will post pics later
niblik
Re: CTR's new toy
Post by niblik »
prove it...
some video evidence would be good... :wink: :mrgreen:
Chopper01
Rock God
choppers new toy
Post by Chopper01 »
right well its been a few weeks now and my pos is just about done. we got the motor all wired thanks to mike for helping out there. It started dam near straight away , she ran a bit rough but that was down to a broken spark plug :roll: :roll:
I started to put the dash back together and get the transfers all oiled up and put the shifters back on . then we spent some time getting the auto shifter sorted out , we had to cut the side of the tunnel out to make it fit then plate it back up,
we got the radatior installed and made up some custom pipe work to join it onto the motor. also had to modify the heater core in the dash as where it went through the fire wall it was going to hit on the throtle body.
Also pulled all the carpet out as was still wet so it had to go, now I would put pics up but someone pinched our camera so I am unable to
But will hopefully take it for a hoon this friday night :mrgreen: :mrgreen: also must say a big thanks to jase as well for his help 8) 8) 8)
Chopper01
Rock God
Re: CTR's new toy
Post by Chopper01 »
well we got a drive shaft , breaks in and blead up , put back in some braces and comected up the steering and
went for a hoon up the street, and to my suprise the farken auto that I pulled apart on the dirty old work bench works the tits :mrgreen: :mrgreen: :mrgreen:
Its so great , the commy motor has a #### load power , I dont know why I did not put it in in the first place :roll: :roll: :roll:
so all and all very happy with my pos at the moment and its about farken time , so on firday night I plan to find where this oil leak is comming from and hook up the guadges and altinator. then its sweet fark all to finish it well it'll never be finshed but it will be certifed
ps it dose farken good skids :mrgreen: :mrgreen: :mrgreen: :mrgreen: :twisted: :twisted: :twisted: :roll: :roll: :roll: 8) 8) 8)
doin_it_dirty
Re: CTR's new toy
mean mate. good to hear, friken mean engines aye, my last comy i had with the v6 i was getting 180km/h in 4th gear, such a basic no bullshit easy engine, that goes nuts. So um, when shall i drop my truck off to ya? just repeat that whole conversion process on my 60. :D If only more of you fabricating and conversion buggers lived closer to my neck a the wood.
Keep us posted mate, would be good to see more pics and vids
