airbags vs bullbars
airbags vs bullbars
Got a issue ,haven't really had a clear answer too . Have a 1997 80 series with airbags , and want to fit arb bar. Told today by dealer, the 80 series bars aren't airbag "crash tested" . Looking at landtransport factsheet it appears to me the bullbars only have to be crash tested/comply on vehicles made after 2003 and fitted with airbags. sent email to LT agency, hoping someone on here may know more than me...
. Factory bumper will last 5min if I leave it on.. Thanks
Re: airbags vs bullbars
ARB Bars are airbag certified and should be ok, they will have a sticker on them or something and all your wof guy needs is to see proof of that. did the Toyota dealer tell you that or the ARB dealer?
Maybe PM the ARB God (Badnuz)
PS Delete your duplicate post
Jerry wrote:ARB Bars are airbag certified and should be ok, they will have a sticker on them or something and all your wof guy needs is to see proof of that. did the Toyota dealer tell you that or the ARB dealer?
At a arb dealer today, thought they were all certified as well, otherwise would have reconsidered truck!! apparently not certified on 80 series bars, was a bit dumb struck.
PM Badnuz .... he might be able to shed more light...
may be something on one of these forums???
http://www.offroad80s.com/portal.php
http://forum.ih8mud.com/80-series-tech/
theres an 80llcool one as well I think
Hi
Have the same truck- e-mailed arb in Aussie.There bars are not airbag compatible.
Brought a steel tjm winch bar which are and have the sticker.
correct the 80 series bars wern't build to be airbag compatible as airbags only came on the 80's from 96... best to by a non airbag 80!!!
Jerry wrote:may be something on one of these forums???
Yeah all the yank guys just fit arb bars, don't seem to have same issues here, airbag sensor is apparently inside cabin by gear shifter. Looks that it takes a almost write off crash to fire the bags whether with a bar or not. no problems 4wding , sounds like airbags hooked into speed sensor as well , ie 4wding speeds. better have a look at tjm then, any pics mudy?? how do you rate them compared to the arb?
Hi cruza
Got plenty of pics not sure on how to post
Heres a link
http://www.thuleracks.co.nz/Portals/61/ ... series.pdf
I put the side steps and bars on as well
Quality and finish seems to be good
Heres a link
mudy wrote:Hi
where from and how much ? did you get the T13 or T15 ?
T15 was about $1250 plus gst from Fully Equipped
mudy wrote:T15 was about $1250 plus gst from Fully Equipped
thats not bad, better than the price i got back from the dealer in ozz
Same problem with the late model GQ's that came in before the change to GU,air bags fitted, but none of the Aussie bars for the GQ's were airbag tested as Aussie doesn't have Jap imports, so have never heard of a GQ with an airbag......
"The early bird may get the worm, but the second mouse gets the cheese....."
It was a couple years ago
