Wanted these bits.
W56 gearbox incl transfer case, clutch and bellhousing
IFS front hubs
Beam axle Hilux stub axles & Aisin free wheelers if available for it.
Contact Glen
021 775 180
WTD : Toyota parts
WTD : Toyota parts
Re: WTD : Toyota parts
madaz068 is wrecking 3 surfs .... will these have the parts you want?
I noticed that - the only bits of any use would be the IFS hubs, the gearbox's are different. But to get the hubs from up there to down here would be more than they are worth.
The W56 box I am after is from the early IFS surfs from 86 to 89.
Cheers.
Cheers.
i have all that in a single cab hilux no wof or reg, w56 is that the g/box that requires cutting the floor pan to fit?? coz i have that one
madterrano wrote: w56 is that the g/box that requires cutting the floor pan to fit?? coz i have that one
Probably is because the transfer case gear lever is further back.
