Madaz's V8 lux
Re: Madaz's V8 lux
Been a bit slack with build posts, so heres a couple:
The finished bullbar design....
And the pretty much finished engine bay....
Re: Madaz's V8 lux
Lovn' that TG fairlead
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Re: Madaz's V8 lux
Thought you might notice that Jafa
Re: Madaz's V8 lux
Looks awesome Madaz.
Matt.
Matt.
Re: Madaz's V8 lux
Been a bit slack at posting pics lately.......
Heres my attempt at keeping the water out of the engine......
And heres the back of the cab finished.....
Re: Madaz's V8 lux
Snorkel looks sweet.
Did you get the noise down to 95db yet? Hope that doesn't restrict the horses.
Re: Madaz's V8 lux
Great looking RIDE, have you thought about the induction noise in your right ear
, If your a smoker it would be ideal for flicking your ash out the window
. I'm very impressed with the quality of your build, all most looks to good to use, keep the build up dates coming.
A LITTLE EACH DAY WILL SEE THE JOB FINISHED,
FITZY.
FITZY.
Re: Madaz's V8 lux
looks good , tidy job:mrgreen:
Re: Madaz's V8 lux
Induction noise is not that bad, sounds pretty sweet.
Had a pretty good argument with the certifer over the db limit, i was 1 db over at idle- which is absoloute bullshit
He declined my suggestion to walk down to the bus station and test a hamilton city bus, and see how much over that was
Also theres plenty of winch trucks which are as loud or louder(Maybe i just need to go to Auckland to get a cert)
Re: Madaz's V8 lux
Re: Madaz's V8 lux
Madaz wrote:Induction noise is not that bad, sounds pretty sweet.
He declined my suggestion to walk down to the bus station and test a hamilton city bus, and see how much over that was![]()
Your certifier is an idiot. 1dB is the JND for the human ear (JND = Just Noticeable Difference, yes it is a technical term
Re: Madaz's V8 lux
Just glue a restricter in the end of the pipe to get a cert then cut it out once you have the little plate firmly attached to the fire wall
Re: Madaz's V8 lux
DieselBoy wrote:Just glue a restricter in the end of the pipe to get a cert then cut it out once you have the little plate firmly attached to the fire wall
Ha ha
Re: Madaz's V8 lux
or bung a few steelo pads up the tail pipe and put a pin thru the the end to keep them there, makes a noticeable difference to volume and very easy to put in and remove later on
Re: Madaz's V8 lux
Passed noise test for cert
94.6 db
Now just need to fix fuel problem or my navi will be running around with a jerry can all day
Re: Madaz's V8 lux
Had to make a trip to the dyno to try and sort out the fueling issues, dyno guys werent too keen on the simexs on their dyno-
Luckly Tony from Speedy Lube had some road pattern 33's lying around.......
Think I need to lower it now..
Re: Madaz's V8 lux
How did the dyno run go?
Matt.
Matt.
- doin_it_dirty
- Bush Crasher
Re: Madaz's V8 lux
damn nice truck, very impressive, all class without bein overtop.
do it right, do it dirty
Re: Madaz's V8 lux
Shiny wheels , shiny paint - not really my thing, but.......
This is a bit more like it...
Re: Madaz's V8 lux
So it does actually go offroad then......
Re: Madaz's V8 lux
Looks good Tim, did ya sort the fuel issue?
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Re: Madaz's V8 lux
GQTROL wrote:So it does actually go offroad then......
Yeah, but i broke it
Jafa wrote:Looks good Tim, did ya sort the fuel issue?
Nope- still getting 3ks per litre
Re: Madaz's V8 lux
What ECU are you using?
What did the dyno run show? Bad AFR's?
Matt.
Matt.
Re: Madaz's V8 lux
Videos a little blurry, but the sound came out allright......
http://s259.photobucket.com/albums/hh286/madaz_/Hilux/?action=view¤t=HPIM1216.flv
Re: Madaz's V8 lux
Mattman wrote:What ECU are you using?
Matt.
Still using the factory ecu, the dyno run showed a few little things that ive fixed, but nothing that would explain its crazy thirst
Re: Madaz's V8 lux
I drive mine quite hard and get around 350km's out of a 70L tank so that's about 5km's per litre.
What AFR were you seeing on the dyno under load? My stock ECU does around 10:1 at full noise so it run's quite rich. Have you got the O2 sensor's hooked up?
Matt.
Matt.
Re: Madaz's V8 lux
Mattman wrote:I drive mine quite hard and get around 350km's out of a 70L tank so that's about 5km's per litre.
Matt.
It was dipping down into the 11s.
At 10:1 you would just about have had fuel running out of the exhaust, I thought your truck had a link running it?
Re: Madaz's V8 lux
I have a Soarer running the stock ECU and a Link in my Hilux. I have two 1UZ's - I am a piglet
Lucky my missus has a 1.6 Civic.
I dyno'd the Soarer recently in preparation for the M90 setup that is about to be bolted to it. Under full load at WOT it was doing about 10.7:1
How are you calculating the fuel economy? I have never bothered calculating the economy of my Hilux, I just use it. Those figures were for my Soarer which only weighs 1500kg's versus the Hilux at around 2000. I did one big road trip in the Hilux and at open road speeds crusing at 100k's I got about 350k's out of the Hilux tank which was around 60L if I remember correctly.
Matt.
Matt.
