Dr_PC wrote:Heath wrote:with the lift It will be sorted
Heath
Heath
In an email I got a couple of months ago from the Chief Scruntineer I was told no lifts in a b e or f Classes
Dont want to see you up in C Class because of something like that
Do not take this as a personal attack Dan as I am sure you understand but how can they say that when the rules for A & B class say
7.1 R ) "Production modified vehicles may fit shackle stops and overset springs may be used , provided they conform to the original design. "
If an overset spring does not create lift what is it ?
If that does not cover aftermarket replacement lifted springs I do not know what would . If you could only reset factory springs there would be no need for the statement "provided they conform to type design" as they already would .
The only reasonable way I can interpretate that rule is springs may be overset and aftermarket overset springs may be used as long as they bolt in , or fit in the factory mounts . How does everyone else read this ?
This is the same as the guard cutting issues a while ago , the end result was that you could cut the guards but not remove material , ok we got that . But as a spectator at a rally last year it was clear over half the trucks I looked at had removed material .
This is the biggest problem in this sport at the moment , these contradictory rules interpretaions . Something needs to be done , it is the most fustrating part of the whole exercise tring to get into this sport . Not saying I know how to fix the problem or know better but I should be able to read a rule book and set up a truck for the class . Dan getting the above message , which in my opinion , contradicts the rules is just , well , frustrating (other F words left out )
Chris
Ps feel free to correct the spelling
