broken fj 40
broken fj 40
ok guys need a right front hub for a fj 40 and axle as well damage photos soon
curly12
Re: broken fj 40
Post by curly12 »
Re: broken fj 40
calling for a flat deck
Re: broken fj 40
more
Re: broken fj 40
You look like a westie in those pics there Coxsy :D
Re: broken fj 40
Thank's big help Jerry. and am a westy who lives in mangere :D
curly12
Re: broken fj 40
Post by curly12 »
Didn't realise it was the southern motorway Coxsy. And problems let me know, my cousin is in the police and in charge of that piece of state highway one ............... :wink: :wink:
Re: broken fj 40
as much as i live here some people are sheep thick gormless ars holes can think of about 8 cars had close calls with the back of the 40 as it sat there with flashers going :D
MNC
Re: broken fj 40
Post by MNC »
coxsy wrote:ok guys need a right front hub for a fj 40 and axle as well damage photos soon
PM sent :wink:
Re: broken fj 40
ok how about throwing 60 axles under it
MNC
Re: broken fj 40
Post by MNC »
coxsy wrote:ok how about throwing 60 axles under it
You've already got disk brakes which would be the main reason to do that. The other is they are about 100mm wider but rekon it would be far easier to fix what you've got and get some rims with a bigger offset.
Just my opinion though...
Re: broken fj 40
ok but can your drum axle be change to disc
Re: broken fj 40
what actually failed coxsy, I've lost a couple of front hubs before but its never made a mess like that? The bearings look pretty dry in those photos? :oops: :oops:
Re: broken fj 40
well the fire in the hub burned a lot of oil before put it out , there is a stub of axle still in the hub , we haven't done a full pull down yet , tonight hopefully
niblik
Re: broken fj 40
Post by niblik »
Sadam_Husain wrote: The bearings look pretty dry in those photos? :oops: :oops:
exactly what i thought, and theres probably the fact that it fuckered the twin locking nut set up and caused it to 'liberise' itself...
Re: broken fj 40
Coz you can see the wheel was still on on the side of the motorway, the lock nuts must have still been on the end of the stub axle at that stage, so was it a failed wheelbearing that decided to heat up to 1,000,000 degrees celcius that caused all that damage?
Re: broken fj 40
pulled the hub apart 50mm of spined axle in there the munched remains of a locknut and a lot of boken hub locks
UBZ
Re: broken fj 40
Post by UBZ »
That is the side it fell over onto, up at Rallywoods QBW. Might have contributed to the failure
Re: broken fj 40
yes righthand side
Re: broken fj 40
went down to terrain tamers in manukau they have NEW hubs, stub ,axles, axles, so the problem is not as big as I first thought , love good news
Re: broken fj 40
didn't find a spring in the righthand axle lock :shock: wrong was there saw it tonight :D
Re: broken fj 40
was going to help put the 40 together tonight hit a bump i know nothing of the cv joints on toymotas , so we will throw the left wheel back on, transport it to a garage to be done next week :?
Re: broken fj 40
the repairs
Re: broken fj 40
we back on the road again
BrentC
Re: broken fj 40
Post by BrentC »
coxsy wrote:didn't find a spring in the righthand axle lock :shock: wrong was there saw it tonight :D
You are lucky that NZ Bus and Truck didn't have to get the parts from Australia - I have twice been subject to their 5 week runaround special of BS, with my truck stuck up on hoist, about parts being ordered and lost btween branches in Aus and then Japan and then the parts arriving in NZ and then needing extra milling etc etc etc etc
Re: broken fj 40
been told i have paid to much of the bits , but its running again , so now we can fix all the other bits that are wrong, bent, missing ,rusted, don't fit,don't work, ie a toyota :D :D
DieselBoy
Re: broken fj 40
Post by DieselBoy »
coxsy wrote:been told i have paid to much of the bits , but its running again , so now we can fix all the other bits that are wrong, bent, missing ,rusted, don't fit,don't work, ie a toyota :D :D
Sounds like you brought a real gem and really appreciate the FJ40 for the 4x4 icon it is :roll:
Re: broken fj 40
yes rebuild the axle hubs next, buy spare cv.s, rust,
Return to “Toyota”
