I started pulling the head apart on the V6, and snapped a head bolt and then started thinking... which is what bought me to this point... so...
The plan:
Motor: either Lexus 4.0 V8 or Holden 304 V8
Trans: Toyota 5-speed
Transfer: Advance Adaptors dual w. W56 transfer cases
Rear axle: standard back end
Rear suspension: MaxiTrac 2" lifted coils and longer shocks, spring spacers if req'd depending on front lift
Front axle: Hilux w. matching diff (4.5?)
Front suspension: Range Rover front radius arms and coils, suitable shocks (probably Rancho 9000s)
Steering: DeRanged hi-steer arms and custom tierod
Driveshafts: rear, stock. front, custom d-cardan Hilux
Wheels/Tyres: Steel 15x8 and Simex 36" extremes
Have I forgotten anything? I'll be using IFS stubs the same as I had on my Hilux to give the same width in the front as the Isuzu rear axle, and as I am going for a few more ponies in this one I expect I won't need to go the low diffs as I did in the MU - so I can stick to the factory 4.5, which means I can keep the rear axle which means much less work... and the factory coil rear axle looks like it will articulate very impressively with little or no work - its a simple and nice design.
Its going to be a 2-week project, just like the MU so I should be driving it by mid next year ;D Although I think most of the problems I had with the SAS in a bighorn are probably sorted, and with no motor/trans while I do the SAS it should be pretty easy to get all the grinding done.
Any thoughts or comments? I'm interested in getting a range of ideas re: the repower - other motors I have considered: Commodore V6, Rover V8 (3.5 or 3.9), P76 V8, 350 Chev, 3Y 2-litre 4 cylinder Toyota (just cos there is one lying on the floor beside the truck at the moment :p)... all options considered - and if you have something that would work and is for sale then all the better
Steve
