downunderxj wrote:I may be wrong but my '95 xj has the NP242 transfer case, so just check before you get too far. The difference is that the NP242 has a hi-4wd position that will allow you to drive on the road, centre diff not locked. So it has hi 2wd, hi 4wd part time, hi 4wd full time, and low 2wd.
Ian
Thanks Ian, yes some XJs did come with the NP242. Its easy to tell the difference, either look at the selector and tell us what do you have or look at the round ID plate on the back of the transfer case and it will say whatever type it is. The ID plate would look like this:
BTW, here is a parts list for NP242:
http://www.drivetrain.com/242transfercasesillust.htmHere is a cut photo of the Selec-Trac (NP 242):
Can you tell where the leak seems to be coming from. If its the seal, it would be around where the rubber boot is (towards the top of the photo).
BTW, Commad-Trac (NP 231) is not really that different from Selec-Trac except that Command-Trac is part-time (i.e. it has no full time 4wd option).
