Reckon you guys could have a look at the pics and maybe help me on how to do this?
minimun wrote:cheers Kiwi Bacon
I ended up snipping into the vacumn line, adding the t fitting and just running off there.
My next question is what should i safely run boost wise on my 3B.... i believe they are a higher compression motor so wonder if i could be causing damage at the boost i'm running
