The basis and start point
Basically a standard 85 sj413 that has had the roof chopped at some point.
After running it like that for a few months and deciding it was a bit low and a bit narrow I was looking to lift/widen it. Thats when I came across a rustyold hilux that I scored for a box and a bottle.
So the plan
suki chassis
hilux 4.88 axles
coils
injected motor
body chop
What I've done
stripped it down and hung the axles off range rover arms with custom A arm in the rear on coils of unknown origin.
rear axle back 250mm
front axle forward 100mm
chopped 200ish of the rear of the chassis
cut and replace front 550mm of chassis to remove drop in rails
Nissan CA18DE 1800cc twin cam injected motor and Auto
Hilux trans adapted to nissan box ( removed 200mm off auto output shaft and had flang put onto hilux spline joiner thing and bolted that to park lock gear. Whole thing is about same length as orignal suzuki box and transfer)
Body chopped off behind the seats
60 series cruiser power steer
winch in place of radiator
Where its at
chassis is painted and complete
body is on (all be it with large hole inthe floor)
new trans tunnel is halfway installed
engine is wired power is half done
Bonnet is just sitting in place.
Left to do
finish wiring
sort rear tray and mount fuel tank and rear radiator and trans cooler and lines for all three
repair and mount bonnet
wire winch
roll cage
mount carbon race seats
air intake
reshape extractors (there a bit wide) and connect to coby muffler
finish trans tunnel and mount shift lever
take it out and thrash it
Think thats about it. Will take some better pics over weekend. Feel free to ask, comment or pull it to bits
