Cheers Richard
Bulletproof wrote:Seeing the ORE Easter trip will be at Reefton I will show a few tracks
Loop track by Petrol hill.
x snip x
Cheers Richard
UBZ wrote:Hey Richard, loving the videos, there is no where like the West Coast![]()
Ive just spend the morning cleaning mud out of my radiator and alternator. have you done any mods to protect these?
I'm also very interested in your modified fuel pump setup. I'm looking at putting a manual pump on my 1KZ and will need a boost compensator for the turbo. Have you modified the 5L pump or are you using a 2LT pump? does the 5L use the same pump as a 2.8? (I'm told this will bolt to the 1KZ)
Cheers Chris.
andrew007 wrote:hi richard,
where is that track in reefton,did you have ur simexs on when you got stuck in that bog?![]()
cheers andy
i'm green with envy,my lux is in bits as broke it on private trip last weekend.what sort of vechiles were the winch trucks,& what kind of suspension set ups?hows the new pandarod set up going on your front diff?
cheers andy
Bulletproof wrote:Mike Tall from "4 wheel drive upgrades" In his V8 Cruiser -Lux became the 1st person ever to drive out of the Chasm. I didn't go because am doing the track at Xmas .
Cheers Richard
Shane wrote:Bulletproof wrote:Mike Tall from "4 wheel drive upgrades" In his V8 Cruiser -Lux became the 1st person ever to drive out of the Chasm. I didn't go because am doing the track at Xmas .
Cheers Richard
I well catch up with Glen later this week and exchange the goss from the weekend,I'll post that vid up of Mike T if I can get it.
I was at Seddonville on weekend also,some guy at the Seddonville hotel was asking after you(uncle maybe?)he saw you cross the bridge or something..
Shane wrote:Heres a track you may know![]()
http://s269.photobucket.com/albums/jj65 ... ure086.flv
Dont know how to make vid come up with pic.
Shane
Shane wrote:On sat morning we did a track on left side going into charming C(mowerbones side)drive short distance then drop in creek wear steel beam/concrete slab are in water drive up stream then out again,trees down across the track every wear,had up to 4 chain saw's going at once,only driving 3-400 meters then out with the saws again.took 4 hrs to clear approx 2.2km.we come to a make shift log bridge that had slumped to one side so couldnt go any further.well put some pics up tomorro
