help wanted
help wanted
whats ive got is a 1985 D/C hilux, failed its wof on friday, too much rust in the tray. ive lined up a aliminuim tray from a single cab hilux, fairly new, not sure what year.
so what i need, is some one around welly who can cut a section out and re-weld it up and maybe the mounts if they dont line up.
any one out there keen and has some time soon?
or next best thing know any one?
thanks in advance
thanks in advance
99 pajero exceed 3.2
Re: help wanted
cough Taz01
he knows how to use one of those welder thingys
Re: help wanted
Jerry wrote:cough Taz01![]()
far cough wheres my coffee bitch!!!!!
WARNING:
Re: help wanted
or you could try Turoa Panel and Paint and Mechanical .....
Re: help wanted
Jerry wrote:or you could try Turoa Panel and Paint and Mechanical .....
I cant weld alloy so had to turn him down
- cool__bananas
Re: help wanted
ask james cause he has advanced mechanical skills
Re: help wanted
I've got a grinder and a roll of duct tape?
could try Stinky ...
- mroffroader
Re: help wanted
You will probably need to tig weld it because its alloy.....find someone that can tig weld well......
Of course don't ask mitch cause hes a useless bitch
cool__bananas wrote:ask james cause he has advanced mechanical skills![]()
80 series tow bus towing a redneck ass vitara
- wgtnnewbie
Re: help wanted
mroffroader wrote:You will probably need to tig weld it because its alloy.....find someone that can tig weld well......cool__bananas wrote:ask james cause he has advanced mechanical skills![]()
Of course don't ask mitch cause hes a useless bitch![]()
ya can mig it you just need to change the feed rollers, gas,tips and filler wire..... so there ya go james ya should be set to do it next time your at tech..........
Re: help wanted
we have a single phase mig changed to a pull type gun to weld ali now, goes so much better that a push wire set up
