new2zukes wrote:well a little update, i have got the winch going (yay) BUT it only goes one wayi have tryed the following method to see if the motor is working correctly:
1)put the winch in freespool
2)dissconect + lead from battery leaving neg one on.
3) dissconect the 3 cables on top of the motor (f1, f2, A)
4) run small jumper wire from A to f1 and put the power from battery to f2. the motor runs fine when i do that.
5) place jumper wire from A to f2 and put the power onto f1 this one does not work it turns the drum very slowly but i cant hear the motor working. if anyone can help me out that would be great thanks.
martin
new2zukes wrote:so its not on the housing itself - its the things on springs when you take the end cap off.
new2zukes wrote:lol just put it all back together but im almost sure that it turns freely one way and a little tighter the other way but it does still turn.
`new2zukes wrote:hi yes have tryed that as i said earlyer in the thread, works great one way but the other it doesnt
new2zukes wrote:
thanks
martin
new2zukes wrote:thanks for that info il get that all done tomorrow night and then i might be able to use the winch on the weekend:) thanks all for your help although its not all done yet so might be back on asking for advice:)cheers
martin
