fj40
fj40
this 40 we got needs spacers on the front wheels to clear the discs on the right side the studs are now short coming through the wheel nuts , is there long studs to buy , to fix this or more drastic changes to be done :D
Pedro
Re: fj40
Post by Pedro »
yup long studs are available from either toyota or a decent 4wd place. i think they are hilux studs
MNC
Re: fj40
Post by MNC »
You can ask for the 60 serise front studs from Toyota - they are longer.
Re: fj40
Thank's guy's. :D
Re: fj40
visted toyota parts in manukau don't stock wheel studs to much trouble to get in hilux of 80' one in for us to see , god how do you guys work with these type of guys :D
Re: fj40
I take it nothing rubbed before and now that you have put a new hub and calliper on the drivers side it now rubs?
Is the rim rubbing on the calliper or is it something else thats rubbing?
Re: fj40
na came with the 10mm spacer , hits the calipar without it, but nuts donnot have enough thread through to be safe ,
Re: fj40
Sounds like the new hubs 10mm narrower than the old one? Maybe you need to talk to NMC about all the spare bits hes got and swap the hub over for one that matches the left hand one? Having to put a spacer on only one wheel sounds a bit dodgey? :? :oops: :mrgreen:
Re: fj40
sorry both wheels have spacers :D
muddy
Re: fj40
Post by muddy »
Mine fits OK with 6mm spacers, although there isn't much of the studs through the wheel nuts. You need 7.5 turns on the nuts according to the rules:
http://www.lvvta.org.nz/stdWheels&Tyres.pdf
page 15/16
Or you could go to the bigger spacers that bolt to the hub, and have their own studs to bolt the wheels on. You'd get the advantage of a more stable vehicle, but with the downside of more load on the wheel bearings...
Re: fj40
we'll run with what we got soon as i find longer studs. was told the holden dealer sells long ones :D
MNC
Re: fj40
Post by MNC »
I've found the Toyota guys up here really helpful, different branch I guess. If they dont have something in stock there are always happy to get them in for you too.
Welcome to come get that diff of mine whenever too. Shes been outside for a while now but I've seen worse cond ones for much more on Trademe. Speaking of that this may interest you, FJ40 front diff with Disc's just need one of the guys on here to bring it up for you:
http://www.trademe.co.nz/Trade-Me-Motor ... 929544.htm
Re: fj40
called in to the lions den [olden dealer] seems they are the guys for wheels studs, 12 studs 20mm longer than stock $120 :D
Re: fj40
started 9.30 am 11,oo now right hub off and clean, left side getting there, :D
Re: fj40
stud higths
I'm happy with this lengthImage
changed the end of the winch cable to cable not 4 feet of chain
Re: fj40
need to replace the shock rubbers next, then sand blast ,sand bog up the body turn it to a soft top again :D
Re: fj40
dam just remembered got to pull the rear axles down for a look too :shock:
Re: fj40
did that needed bolts to wind off the drums off the hub full of dirt , rebuild time again, slave cyl' s shoes maybe retainers
Re: fj40
new slave cyl s are $48 for 2, new drums as they are 2mm off oversize $87.40 +gst each :D
Re: fj40
bleed the brakes again ajusted the rears, up the thing stops now :D
Re: fj40
now happy with the front end and brakes , took it for wheel alinement , found it need wedge plates as thrust on the front is wrong, also both axles track to the right
wopass
Re: fj40
Post by wopass »
truck stops for castor wedges :wink:
pagar
Re: fj40
Post by pagar »
dam coxy that will be a new truck by the time you are finished.
Re: fj40
the poor neglected needs it , its a trial for my wife this truck :lol:
Re: fj40
the new look for summer till he pulls the body off
Re: fj40
60 series landcruiser steering arriving next week :D
Re: fj40
well its here box, pump steering shafts drag and tie rods as well , all the hoses
UBZ
Re: fj40
Post by UBZ »
When is James going to sign up and start a build up thread for his 40 :?: :wink: Its going to be completely new by the time you guys are finished with it.
MNC
Re: fj40
Post by MNC »
coxsy wrote:called in to the lions den [olden dealer] seems they are the guys for wheels studs, 12 studs 20mm longer than stock $120 :D
Guys at North Shore Toyota have ordered 12 60 series (front) studs for me. I called today and they will be there tomorrow morning at 8:30am, cost $86 8)
Re: fj40
hope so but it hard to get him moving on it, the wof runs out in feb will start rebuilt properly then, so we can take it for a run up thompsons before then :D
also as this truck has endless air finding a place for the power pump could be interesting?
Return to “Toyota”
