Welded Front Diff ?????
anyone done it and opinion please ie: works or not
WARNING:
- Sadam_Husain
- Angry bird
Re: Welded Front Diff ?????
when I turn my front diff lock on I cant steer
Get some bigger tyres Taz
Bro in law smashed his front diff on recent Ashley trip in his MU. So decided to weld it up as nothing to lose.
He certainly noticed the extra traction, but also is noticeably scuffing on hard turning on shingle. He managed to smash that soon after - pulled it out and discovered welds had broken - had it re welded and put back in on sunday and went out for a drive and play - that's the last I heard.
Nothing like a weldwell locker for economy
my old crawler had a welded front diff and it was great tratction , the problems with it was hard turning circle and smashing cv's till I bought longs
- rangimotors
weld the rear put the locker in the front
yep already welded the rear thinking of welding the front as well............
WARNING:
rangimotors wrote:weld the rear put the locker in the front
x 2 here Taz
taz01 wrote:yep already welded the rear thinking of welding the front as well............
don't weld front, throws you off hill and off camber tracks in a flash, been there got the rollover to match
Pedro
- cool__bananas
Pedro wrote:taz01 wrote:yep already welded the rear thinking of welding the front as well............
Pedro
you know what happens when going up a hill with 2 locked diffs ae
i welded the front diff on my vitara after running out of spares and thought it would be a temperory thing but i love it , it is now a true 4wd with both welded and it didnt affect my steering as much as i thought it would , it makes it a lot easier to drive slowy over stuff , problem now is dont want to change back but probaly will for summer.
vaughan
vaughan
Im fairly certain its illegal to have a fulltime locked differential for a roading going vehicle.
if its only used offroad its not a problem...but as others have said in the front it makes turning a bit of a problem at times.
I think for a selectable 4wd in the front is ok as its not used on road???
fweddy wrote:I think for a selectable 4wd in the front is ok as its not used on road???
Only if you've got (and use) freewheeling hubs.
