warn m8000 cant get it going
new2zukes
Re: warn m8000 cant get it going
Post by new2zukes »
take photos of it as you pull it down and build it up again. Along with a commentary, this thread would be a valuable resource in the tech section.
il take some more photos when i can workout how to get it apart :P was trying to get it off tonight but wouldnt budge then looked down the drum and there is a clip of some sort that is stopping it from moving. to get it out do i have to hit the long end of the hammer down this end?
and if so do i need to try and get the clip that is on there off.?
new2zukes
Post by new2zukes »
well ive been out and bashed some more at the dam brake but it just wont budge and ive broken 2 hammer handles trying to get it out. is there anything i should no before i do something i shouldnt
Madaz
Post by Madaz »
If you trying to hit it down the drum from how your holding it in the picture, you are hitting it the wrong way
curious_george
Post by curious_george »
new2zukes wrote:well ive been out and bashed some more at the dam brake but it just wont budge and ive broken 2 hammer handles trying to get it out. is there anything i should no before i do something i shouldnt
Your hammer is too small :mrgreen:
I know, I know - it's no help but it's too hard to resist!
new2zukes
Post by new2zukes »
realised it was the wrong way but not tryed the sledge hammer hitting it the right way and still no movement will try again tomorrow with a bigger hammer!!
Madaz
Post by Madaz »
Pour a shit load of wd-40 down there when you leave it overnight to help break down the old grease
new2zukes
Post by new2zukes »
well got the brake out thanks to a m8. took him a few hours though as it was soo stuck. cleaned all the bits and pieces up and put them all in order as this may help other people distinguish the parts on the drawing to the real thing.
first is the motor assembly.
then its the break assembly all in bits but NOT IN ORDER as it all fell apart when it came out and most of the brake assembly is stuffed so its time for a new one.
now is the gears which i will finish cleaning up tomorrow as there was a ton of water in with the grease which is usually not a good sign. so il re greese tomorrow too.
and if anyone wants the parts breakdown it is on the warn website :http://www.warn.com/truck/ReplacementParts/parts/8/srrpl113-114.pdf
Bulletproof
Post by Bulletproof »
A very worthwhile mod is to put a drain in the planetary gear end of winch if you are going to be in water. The water comes in through the ends of the drum and it cant get out so the winch is half full of water all the time.
This in turn is what makes the brake rust.
I haven't got any pictures of my old 9000 ti but what I did was grind a channel up the side of the planetary housing going right through the big planetary gear to take a 7mm piece of plastic to work as a drain. On the end of that you can fit some heat shrink and squeeze the end so water can come out but shit doesn't go the other way.
Works a treat.
I now have the latest 9500 Ti and they have seals on both ends of the drum to solve that problem.
Cheers Richard
Never say die, up man and try
new2zukes
Post by new2zukes »
sounds like the sorta thing id do to stuff the winch up lol but i dont think i will be in too much water just lots of mud and hill driving but every now and then i would pull the winch apart for a look. i have a chip well a big one in the houseing pictured below is there any way to fill this up so water doesnt get in as much. i tryed welding but the mig wire wont stick.
martin
Pedro
Post by Pedro »
new2zukes wrote:sounds like the sorta thing id do to stuff the winch up lol but i dont think i will be in too much water just lots of mud and hill driving but every now and then i would pull the winch apart for a look. i have a chip well a big one in the houseing pictured below is there any way to fill this up so water doesnt get in as much. i tryed welding but the mig wire wont stick.
martin
it is probably aliminium, either get it tigged up at a local engineers or use some "kneadit" very good epoxy repair putty, just clean the surface so it is clean but rough, and mold to shape
pedro
new2zukes
Post by new2zukes »
well a little update, i finally got my winch brake assembly after waiting for a long time for the part to come into the country. pics here:
it is not the same brake as the one that came out but it works ok. here is it inside the drum.
the only problem i have atm is that the motor will only go one way and when it turns the drum there is a horrid crunching noise in the gears but only when the clutch is engaged. does anyone know what this could be?
martin
Return to “Tool Shed”
