I went and saw a eng/fab this morning and talked about getting some work done on my 60 surf, those of you in Auckland may know him, Bernie from Counties/Manukau 4x4. Now i was considering the Falcoon spring swap, seems to be the way to go on these solid axle surfs. Though he had never done it to a truck so he suggested a couple other mods which sounded bloody good. Now i 4got the correct names of the parts/mods, but he said once i buy a full set of raised springs and some good long travel shocks, you can fit a double shackle thingy (double jointed)
which when you need drop it basically gives you double of what the standard shackle would.
Then one other common quick mod is mounting part of the old spring with the shackle end mount to the chassis, so that the shackle mount is still in the same place, but the fixed point is approx 300mm forward, so everything still sits relatively the same, but the shackle isnt fixed at the point, its got that much more flex/drop from that length of spring. May all sound a fit confusing, but i hope that if someone has had this done they know what im talking about, so it would be good to hear some feedback on this mod, how good is it? what are those double shackle things called and could i see some pics of it???
Cheers in advance
