Well me and a mate took our utes down to Rerewhakaaitu for a play on the weekend, lake was quite a bit higher than last time I was there, ended up taking a bit of a deeper swim than planned when i found some large holes in the track under the water
Anyways to the problem at hand, the low oil pressure light now flickers on start up and then stays on all the time, pressure on the gauge is fine no sign of leaks. Still the same today, any ideas? could be still water sitting in the sensor connectors? or something had a nice warm day today to dry out today. Now i can see the large sensor infront of the oil filters, is this the one for the light or the gauge? I assume they dont both run off the same sensor or they would both be not working. There is a small amount of grass and weeds still between there and the starter
Other than this a good day out..carpets needed a wash anyway
