SMOKEY wrote:Richard, where is your EGT probe located ? those temperatures seem to be very low to me. I know your motor is fitted with an extractor exhaust, is it four into one and is the probe at the collector ?????. My 2LTE ( 2.4 turbo Toyota ) has the probe in the exhaust manifold just before the turbo mounting flange where it can read all four cylinders and where my research told me you should be about 7 to 8 inches from the exhaust valve, in my case it is the head ports. If I was to drive at 450/550deg C I would be idling around, I drive mine up to 650 with the 700 deg C reached for very short duration and cruise with the caravan on the back at 600 deg C all day. I would never own another diesel with out fitting a EGT gauge, like you I drive to it all the time and despite what 2's says about the 2.4 mine just clocked up over 200,000 km and hasn't gone = boom .
KEEP COOL MAN,
FITZY.
Hi Fitzy
The figures of 450-550 would be under normal driving 95% of the time. On a hill or overtaking I will allow it to go to 650 but only for short periods of time. It is easy to control by lifting the foot slightly or changing down.
Mine is fitted in the collector of the four pipes of the extractors and because I don't have a turbo are generally getting a reading less than one fitted before a turbo.
As you say keep it cool.
Cheers Richard
