before/after(deg C)
idle = 150/95 = 37% cooler
3rd gear 2000rpm = 250/175 = 30% cooler
4th gear 2000rpm = 340/250 = 26% cooler
100kph = 450/375 = 16% cooler
works out to about 75 deg c cooler temps on average which has to be better for the engine.
full throttle acceleration stayed the same at 500 deg c. and less engine braking. both of which i expected but didn't expect to see such a large difference in exhaust temps
this is a 1kz-te engine installed in my double cab hilux.
next hoping to install intercooler to see if that makes any diff then wind the boost & fuel up
