2001 A arms
For all Suzuki related topics
2001 A arms
lower A arm, s has anyone repaired these cast ones at all :D balljoint stuffed
Re: 2001 A arms
found second hand at tepuke $200 new are $4oo + found you can drill the casting on the otherside an pump grease into the joint
Heath
Re: 2001 A arms
Post by Heath »
just fit a grease nipple eh?
Re: 2001 A arms
yep we going to do the other side as well to increase their usable life :lol:
Re: 2001 A arms
drilled another the other day moved the grease nipple to a different place to make it more accessable, first time ended up under the front axle shaft
Return to “Suzuki”
