Transfer Bearings
For all Suzuki related topics
2MEKE
Transfer Bearings
Post by 2MEKE »
Does anyone have a list of bearing and seal number for an SJ410 transfer case?
UBZ
Re: Transfer Bearings
Post by UBZ »
What year 410?
84+ 410 have the same transfer bearings as a 413. I can dig out my part numbers for you . cost me about $150 for all the main roller bearings and 3 seals.
2MEKE
Post by 2MEKE »
That would be awesome if you could.
It's an '84 (4wd switch model) so your number are most likely the right ones
UBZ
Post by UBZ »
Can't find my docket but ive the part numbers off the boxes. The bearings i have are NSK brand from Japan.
http://www.nsk.com
I got them from Presion Bearings in New Lynn Auckland. About $150
They are the Local NSK dealer, should be one in Whangarai.
# 6306NR*C3 703 (Large roller bearing with Circlip) x1
# 62/28C3 801 (Main Roller bearings) x 3
# 63/22C3 807 (Input shalf end roller bearing) x 1
# TC12539 (Smaller Seal, Front output i think? ) x1
# TC12545 (Larger Seal) x2
2MEKE
Post by 2MEKE »
Cheers :D
lneil
Post by lneil »
If you have no joy with then, let me know and I'll find the Suzuki part numbers for you.
Return to “Suzuki”
