pinion
brakes-shocks-lockers-etc
abbo
pinion
Post by abbo »
I have just got myself a 85 bj 70 and the rear drive shaft is rocking around alot.I have been told its the pinion bearing,it makes afunny noise when you take off but then its sweet. All so been told it could be the crush spacer....????? When the truck is stopped and get under it you can move it very easy . So if anyone can shine any light on my problem that would be great...thanks abbo :mrgreen:
Dace
Re: pinion
Post by Dace »
abbo wrote:I have just got myself a 85 bj 70 and the rear drive shaft is rocking around alot.I have been told its the pinion bearing,it makes afunny noise when you take off but then its sweet. All so been told it could be the crush spacer....????? When the truck is stopped and get under it you can move it very easy . So if anyone can shine any light on my problem that would be great...thanks abbo :mrgreen:
Sounds like the pinion bearing, I replaced mine in the Hilux earlier this year
pay to sort it asap before ya damage the pinion or ring gear
Re: pinion
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Beer_Cruiser
Re: pinion
Post by Beer_Cruiser »
Jerry wrote::D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Love that CRUISER GRIN...
badnuz
Re: pinion
Post by badnuz »
pays to do the pinion seal the crush tube and both bearings if its apart :D ..... and ABBO YOU THE MAN!! :D :D welcome to the best 4wds!!! :twisted:
(wait for it... wait for it....) :mrgreen:
(editted for effect)
Bulletproof
Re: pinion
Post by Bulletproof »
If you are doing serious 4 wheeling it pays to throw the crush spacer away and set the pinion up with a solid spacer and shims.
They are miles better
Cheers Richard
Never say die, up man and try
Re: pinion
Lets not forget Nicks Grin as well :D
cool__bananas
Re: pinion
Post by cool__bananas »
Bulletproof wrote:If you are doing serious 4 wheeling it pays to throw the crush spacer away and set the pinion up with a solid spacer and shims.
Cheers Richard
whats wrong with crush spacers? ive never broken a diff due to a crush spacer?
Pedro
Re: pinion
Post by Pedro »
Cheers Richard
you just need the solid spacer under the gas pedal :lol: :lol:
cool__bananas
Re: pinion
Cheers Richard
:D
Bulletproof
Re: pinion
Cheers Richard
The only advantage of a crush tube is that it is quicker to set the preload of the pinion up but is not as strong as a solid spacer that all the old trucks had.
The crush tubes in the real world are a real problem because a pinion flange under load only has to hit a boulder and the preload then is then stuffed and the diff self destructs .
The problem is so bad some of the mines on the west coast are converting all there trucks to solid spacers to save their diffs.
Cheers Richard
Jafa
Re: pinion
Post by Jafa »
A solid spacer is defintely the way to go, stops any chance of the pinion being shoved back by hitting something as Bulletproof said, but if you really want to save your Toyota's diffs, then crank the carrier bearing preload to 150ft/lbs, ie turn the carrier bearing adjuster nuts in another 1/4 to 1/3 of a turn more from stock settings, prevents gear deflection, ie broken teeth
have a look here
This guy "Zuk" has been building top class diffs for years, most of the competitors on rock racing etc use his diffs
http://www.gearinstalls.com/freshen.htm
021 273 9942
jafa@inspire.net.nz
abbo
Re: pinion
Post by abbo »
:lol: :lol: :lol: :lol: :lol: :lol: :lol: ....Thanks very much on the ideas got home today and looks like curlys been here bits everywhere :shock: :shock: :mrgreen:
Don't have 4wd.
curly12
Re: pinion
Post by curly12 »
Yep,outer bearing farked, as well as the inner one, oil like mud, anyone here with a loaner diff while we rebuild this one???
jumper
Re: pinion
Post by jumper »
i have a welded diff sitting on the shelf if its needed
microwaved cheese on toast
Beer_Cruiser
Re: pinion
I got a 4.1 diff with a broken pinion shaft
Can it be fixed and get you going . Is in the shed
Re: pinion
abbo wrote: So if anyone can shine any light on my problem that would be great...thanks abbo :mrgreen:
curly12
Re: pinion
Post by curly12 »
Well it is a toyota :roll: :roll: :roll: :roll:
See that now you drive a Nissan Skid, your true colours are coming out :lol: :lol:
abbo
Re: pinion
Post by abbo »
This is to both of you's bite me f##kers. :mrgreen:
Don't have 4wd.
Re: pinion
WOULD YOU LIKE SOME CHOCOLATE ICING WITH THOSE LEMONS ABBO
OH WAIT YOU HAVE PLENTY IN YOUR REAR DIFF
abbo
Re: pinion
Post by abbo »
skid wrote:WOULD YOU LIKE SOME CHOCOLATE ICING WITH THOSE LEMONS ABBO
Thanks man :lol: :lol: :lol: :lol: :lol: :lol:
Don't have 4wd.
Re: pinion
ITS MY PLEASURE DUDE
i KNOW YOU LOT WOULD DO THE SAME FOR ME IF I HAD A TOY
sig
Jeep Jeep
Re: pinion
Post by sig »
have you had any luck finding a loaner head abbo
Re: pinion
sig wrote:have you had any luck finding a loaner head abbo
viewtopic.php?f=34&t=14022&st=0&sk=t&sd=a&start=30#p158593
abbo
Re: pinion
Post by abbo »
Yes i have thanks sig. Sadam was the man for that :D I need to find a fan for it now then fingers crossed i will get to have ago at the fwl :D
Don't have 4wd.
Re: pinion
can you measure the fan size and the mounting plate thingy size?
abbo
Re: pinion
Post by abbo »
Jerry wrote:can you measure the fan size and the mounting plate thingy size?
I got one today... :D But payed thru the teeth for it :x :x :shock: So looks like i will be going now :wink: All i need now is curlys tyres :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: So is the lexpos going to roar jerry...??? Is it all go.. :?: :wink: :P :mrgreen:
Don't have 4wd.
Re: pinion
Rob has some creepys half worn sitting in one of his racks
