SJ413 clutch
For all Suzuki related topics
Big-AL
SJ413 clutch
Post by Big-AL »
i am having a few problems with the clutch in my 85 SJ413. After i have been thru a few watery type mud holes the clutch sticks. I press the clutch pedal in, but i cant put it into gear. With the vehicle off i put it in 1st low, and just crash started it off the starter motor, but if i stop the vehicle with the clutch pressed in, it stalls. So i would guess the clutch is not releasing.
It only does it after i have been thru watery mud, and it always comes right in a few days by itself. it will drive fine on firm ground, or boggy mud (if you know what i mean) but the clutch will always get stuck after watery mud.
i have read thru the old topics about this problem, i have tried putting a hose in the bellhousing thru the clutch fork hole, and pumping the clutch while doing this. But that didnt seem to work, altho i was surprised that the water running thru and coming out the bottom of the bell housing was clear.
any other ideas what i can try? ... i am not particularly mechanical (if you couldnt tell ;)) but i am will to give things a go.
UBZ
Re: SJ413 clutch
Post by UBZ »
Have you pulled the gear box and had a look at the clutch?
Could be crap on the splines stopping the release bearing / or clutch from sliding back and forth.
Give me a yell if you want a hand to pull it out.
Big-AL
Re: SJ413 clutch
Post by Big-AL »
i havent pulled it to bits yet, i was hoping not to have to do that :P but i am thinking i might have to...
gimmemud
Re: SJ413 clutch
Post by gimmemud »
Big-AL wrote:It only does it after i have been thru watery mud, and it always comes right in a few days by itself. it will drive fine on firm ground, or boggy mud (if you know what i mean) but the clutch will always get stuck after watery mud.
He means the kind of watery mud that does this.
I'll give ya a hand and i know someone with a very large truck pit :lol: :lol: :lol:
Big-AL
Re: SJ413 clutch
Post by Big-AL »
This sort of mud ...
Re: SJ413 clutch
something may have done a bit of rusting up in there... might be time to pull the gearbox out an have a wee look and clean it all up or better still maybe its time to throw a new clutch in there for peace of mind :mrgreen: :mrgreen:
UBZ
Re: SJ413 clutch
Post by UBZ »
Big-AL wrote:This sort of mud ...
I recognize that alternator cooking mud hole, and I think some of that mud is still in my engine bay.
Big-AL
Re: SJ413 clutch
Post by Big-AL »
yeah, i want to take it to the xmas bbq, so i might start on pulling it to bits, sounds like i have got a few offers for help :)
Satalite
Re: SJ413 clutch
Post by Satalite »
You only got this week and next so get cracking :lol: :lol:
Re: SJ413 clutch
Satalite wrote:You only got this week and next so get cracking :lol: :lol:
one night to slip the gearbox out and see whats wrong, another day to sourse the parts and the next night to shove the gearbox back in and its all fixed so that will leave about 1 and a half weeks spare :mrgreen: :mrgreen:
Big-AL
Re: SJ413 clutch
Post by Big-AL »
is that another offer for help? :P
Re: SJ413 clutch
That was the way I read it :mrgreen: :mrgreen:
icekayak
Re: SJ413 clutch
Post by icekayak »
Whats the easiest way to change the clutch? Slip the motor forward a touch, and pull the gearbox out or ???
gimmemud
Re: SJ413 clutch
Post by gimmemud »
icekayak wrote:Whats the easiest way to change the clutch? Slip the motor forward a touch, and pull the gearbox out or ???
IMO i would take the engine out to be the easiest way. After changing my engine thats what i reckon and since there are like three wires to take off and the engine only takes up about 3% of the engine bay in al's should be able to do it reletively quickly. Do you guys have an engine crane? or we could just lift it out by hand :lol: :lol:
Big-AL
Re: SJ413 clutch
Post by Big-AL »
UBZ wrote:Have you pulled the gear box and had a look at the clutch?
does that offer for help still stand? do you think there is time to do it before the bbq?
DieselBoy
Re: SJ413 clutch
Post by DieselBoy »
Fark takin the engine out, just lift teh body off!!!!! :D :D
All you do in a zook, is take the intermediate driveshaft off ( the one between the gearbox and the transfercase, 8 x 12mm bolts), undo the 4 bell housing bolts, undo the the cross member, take the Knob off the gear leaver, then move the box rewards and then down carefully.
Easy peasy, can do it your self with a trolly jack, but much more fun with two people. As the transfercase is not connected to the gearbox, the gear box weighs less than F.A, you can carry it around tucked under one arm.
Like sadam said, its a saturday job.
Ring up and get your self a clutch kit tomorrow (might as well replace while its apart) and slip it in on Saturday.
Big-AL
Re: SJ413 clutch
Post by Big-AL »
you make it sound so easy :)
DieselBoy
Re: SJ413 clutch
Post by DieselBoy »
IT IS!!!!!
Its a Zook, everything is easy to work on, its light, and there is plenty of room to get at stuff!!!!!
Just get ya spanners and socket set out and go for it, you'l have the box on the ground before you even think about morning coffee!!!!!
UBZ
Re: SJ413 clutch
Post by UBZ »
I can give you a hand on Saturday Afternoon if you want.
Not to hard, as DB said.
I normally drain the gearbox to stop all the oil coming out the back after you pull out the jack shalf, so you might want to replace that at the same time.
You need to go up today and water blast the 3 inchs on mud off the under side so we can get at the bolts. :roll: :roll:
Big-AL
Re: SJ413 clutch
Post by Big-AL »
Thanks heaps to UBZ!!!!!
We spent sunday pulling the gear box out, found that the thrust bearing had worn. We replaced it, cleaned and greased everything, and put everthing back together + replaced a universal, the clutch cable, and set the timing :) all by about 3:30.
apart from some sunburn :oops: everything went well, and zuk is purrrrrrring :)
Thanks again for your help UBZ.
Re: SJ413 clutch
Good stuff Al..... easy wasnt it 8) 8)
Big-AL
Re: SJ413 clutch
Post by Big-AL »
yeah it was easier than i thought, but it was made alot easier by UBZ, at least one of us knew what we were doing :P
Return to “Suzuki”
