After all the playing round with the suspension this is the end result
By now he's done a few runs and discovered that 30" tires rub a bit hard in the back arch... to the piont where they are peeling the gard lip open and cutting his rear tyres and he wanted 32"s so we needed to lift the body after alot of stuffing around found out there is several issues with the body mounts... first off they have captive bolts (welded into the body) and are in really difficult to get to places that you'd have to cut the floor to remove second the bolts are a bastard length and are stepped in dia
after alot of talking (brainstorming
) came to the conclusion that the shortest lift I could do at a resumble price wasn't going to be as cheap as the Calmini kit so we went with that ... what a mistake the kit has more than a few issues standard and in my opinion dangerous
this is the reason no more pics were put up here
Heres why....
First off and worst of all the dangerous bit the main body mounts these are the bits that hold the body to the chassi... this is what holds everything together...
A washer isn't to bad till you consider its covering a hole in the chassi that is big enough that the head of the bolt drops through with room to spare then you consider its not even a HD washer its just a standard mild steel one!!! and isn't even big enough to stop this
And thats the bolt that is sposed to go there
Based on the fact we had it and he is a good enough bastard that he wouldn't sell it once we started finding the issues, we decided to fix it, this is what I came up with replaced there pithetic washer with a disk from the top of my spacer block (cut form 4mm plate
) oh and note even that has deformed some when tightened
Up front there was another issue that made us cringe the front cab mounts are these nice machined plastic ones, problem is if you follow there instructions your sposed to put the original rubber pad ontop of the plastic block with the block resting on the chassi the issue is the cheap bastards made it to small in dia and it only just and we are talking a couple of mm here sits ontop of the depression for the rubber any missalignment or a knock once its in will have it side loaded not good at all easy fix for this one thank fully ignore there instructions and put the rubber pad below
Next issue is the chassi spacer blocks, these ones
They were too short so I had to weld some extra flat on them so they touched the rubber pads
oh and the final laugh to be had with this came the next day when we found one night out in the dew (no rain
) was enough to start rust showing on the edges of the galved spacer blocks
One other mod I did to the kit is the gear stick extension they recomend but welding it I drilled and pined it before I welded it, but thats just me
My impression of this kit
Cheap, Nasty and Dangerous !!
Do not buy it, the fact they are willing to put somebodys life at risk to save (or make a few bucks for themselves) is shocking !!
Right I've got to go to work
Cheers Reece
