I was wondering if someone could shed some light on these.Im picking up a 86 Terrano (an oldie but a goodie
Now its a NON turbo 2.7 but the engine number starts with TD27.I assumed TD stood for turbo diesel???
Armz wrote:tgaguy1 is spot on, terrano is the the same as the safaris - well except the fact the only 2.7 wif 4 cylinders n not 4.2 6cylinders, its the T on the end that stands for turbo.
My understanding with the Turbos is up untill about the 96 model they were factory on Autos but the manuals were naturally aspirated, same with the safaris, but it is a very common mod to add the turbos to the manuals.
Im never wrong thou sometimes I am mistakenIf anyone wants to correct me on that
darinz wrote:OT but are you the guy I was talking to at Union Car Spares a couple of weeks ago???
tweake wrote:is it one of the motors with the fuel heater at the back of the block. if its got fuel lines running to the block just check the heater as it may have cracked and your leaking diesel into the water.
darinz wrote:I had a chat with Grant and he is pretty certain your problem is inside the radiator. ie it needs to have a tank pulled off and a good clean out. Until you've had this done then the flow though the radiator just isn't enough to cool things.
As for the Terrano, once money starts to flow I'll start work on it, not sure when that will be but what I have planned may suprise a few people. That is if it works, if it doesn't a few will have a good laugh at my expense. Such is life!!!
