height control
height control
Does anyone know where the height control moudle is on a 91 swb gen 2 3L V6
Re: height control
I have a feeling the ECU is located in the rear passenger side panel trim. Just back from where the rear speakers are. NJs Pajero Project post has a picture of this area as his diff lock compressor is in the same place. I believe its one of the ones located next to this.
Are you having issues with it?
Re: height control
thanks for that. found the problem today, some ome had done a doogy repair on over drive wiring under gear leaver and was shorting out
