Service
Service
Just one question, im about to service my truck, ive done heaps of petrol cars before, but not a deisel 4x4, is there any difference to it, appart from the extra costs for parts. ie same old thing for oil, undo the cap, undo the bung, unscrew the oil filter, drain, fit new filter, screw bung back in, fill and close off?? Cheers for any advise
Re: Service
dont forget to do the fuel filter as well
Re: Service
...and air filter if required.
~ Good roads lead to bad fishing. ~ Eric Wight, Maine Game Warden ~
Re: Service
If you are unsure of the trucks service history its worth checking
Dif's x2
Transfer box x1
Grease nipples on both drive shafts
Check / repack both front hubs
Dif's x2
Transfer box x1
Re: Service
is the fuel filter done the same as a petrol?, i for some reason was thinking it could be a bit tricker being diesel??
Re: Service
Paulie81 wrote:Just one question, im about to service my truck, ive done heaps of petrol cars before, but not a deisel 4x4, is there any difference to it, appart from the extra costs for parts. ie same old thing for oil, undo the cap, undo the bung, unscrew the oil filter, drain, fit new filter, screw bung back in, fill and close off?? Cheers for any advise
Exactly the same, except you have to bleed the fuel system after changing the fuel filter. I always fill the fuel filter with clean diesel before I screw it on; it saves having to pump the hand primer pump a million times to fill it from the tank.
Re: Service
tgaguy1 wrote:Paulie81 wrote:Just one question, im about to service my truck, ive done heaps of petrol cars before, but not a deisel 4x4, is there any difference to it, appart from the extra costs for parts. ie same old thing for oil, undo the cap, undo the bung, unscrew the oil filter, drain, fit new filter, screw bung back in, fill and close off?? Cheers for any advise
No idea of the construction of the fuel filter you use but, yep, likewise, be very careful not to spill the unfiltered fuel into the injector pump side of the filter. Make sure you use a funnel or similar to get the unfiltered fuel into the side where it'll be filtered once the engine is started - if you know what I mean...
and X2 on checking all the diff, t/box and gearbox oils etc. Also is a good time to check diff breathers if fitted for seals etc.
Re: Service
sweet, cheers guys, might leave the fuel filter till when ive got my mate around and he can give me a hand there, so i dont F it up, as i need it to take away.
