I failed a wof due to damage to the seatbelt (jammed in door), and of course, knowing my luck, its a pre tension seatbelt (read $$$$$$).
Do I have to replace it with the same, or can I go for a standard one, and is there a big difference?
Also, anyone know if the GQ/GU belts are the same, or is there anyone that can take a pic of the top mount on theirs and send it to me?
GU standard is $195+ gst
GU Pre Tension $400+ gst
GQ $40
Dave
Pre tension seatbelts?
Re: Pre tension seatbelts?
if you have airbags they need to be pretensioned i think, can you get one from a wrecker?
http://www.ukcar.co.uk/features/tech/ot ... /index.htm
Yeah, those are wrecker prices
I thought it was something to do with airbags, but the $195 one was from an airbag model
Is there not a rule that 4x4 can use a lap/diaginal type belt [ cheaper ]
