After the pictures were taken it rained for the rest of the night....
IcedJohnno wrote:What does the device the Saffi is towing do?
Is it a portable winch?
GQTROL wrote:Truck seems to go alright...thought you was gonna get stuck on the exit though!
Madaz wrote:Probaly not the best of photos, but heres the latest silly thing ive done to the hilux........
Ever wondered if a Nissan GQ front diff head would fit into a cruza housing and give you a high pinion diff without going to a 8" hilux sized one?
Will see if it survives the Northland Comp........
Bulletproof wrote:
Why would you want to sacrifice clearance with a Big diff head ? All the latest cruisers have the high pinion 8 inch at the front.
Cheers Richard
vvega wrote:what do you have under your diff
with 35" bfg's that measure 34.5"@28psi i have 315mm from the lowest point to the ground @45 psi lol not that helpfull really
mroffroader wrote:vvega wrote:what do you have under your diff
Are prado diffs bigger?? I have prado axles under my vitara and i have 36" iroks which measure more like 36.6" and I have about 310mm?? I thought they were the same as lux's?
turoa wrote:mroffroader wrote:vvega wrote:what do you have under your diff
no they are the same size. you must either have a broken measuring stick or are a mathmatical retard
xorph wrote:Wow that diff swap is very interesting, Did you break the old diff?
what was required to fit the diff?
did the axle shafts need modification? did you have to cut off the old diff bolt flange and weld a new one on?
Cheers, Matt
