Working on getting new diff in Prado along with new seats
20th - 21st Dec Xmas nearly here
Well never started one of these
Re: 20th - 21st Dec Xmas nearly here
well finished work at 12.30 today went and got a warrant on the boat trailer then came home and stripped my transporter trailer that i carry my zuke on down to its frame work and started grinding the stupid little bits n pieces of steel off that i have no idea wat they are for. but anyways tomorrow il be cut and welding some sides on it as the trailer bends heeps when the zuke is on there.
driving home at 5pm, middle of peak hour traffic and snapped the rear drive shaft in the old shiita hilux, came to a complete stop in the middle of the terrece tunnel
. no worries, got out and put it it 4wd and saved my arse that way. pretty embarassing tho
99 pajero exceed 3.2
put new front drivers side wheel bearing in on jeep.....@275.00 a side,will put other one in some time on the weekend, then back to the wof man....
v8 tj...luvs the gas......
in garage cutting,grinding,welding stuff... fun!!
- Dr_PC
New shocks for the buggy see if that will stop the falling over
- skid
- Tyre Man
I may give the 80 a kick as I walk past it this weekend, just to let it know I'm still alive
well last night i whound my front torsion bars up to level it back out from when i lited it last year.slipped off the nut with th socket and powerbar and scored myself a bit ot a black eye
oh well it was heading for my nose,would have broken it if i hadnt turned my head.
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
SAM
well spent the week puting a new 350 in the hilux the mew motor runs mint easy to fry 35s in 2nd lol
- safaripete
what happened to the 400 you were gonna put in there bud
went to a local school with my trials truck and gave rides to Cancer kids, at thier xmas bbq/party, it was pissing with rain and the field had 20mm of standing water, bloody wet but the kids had a great time, hope the grass grows back on the school field before next term
Pedro
Pedro
the 400 is a bit to flash to put in the lux so i took the 350 out of my fc holden and the 400 will be going in it
Got energised to pull the front hubs etc off the front and remove the disk brake covers (and paint the calipersd after cleaning them a little. Had a tool made up at work to remove the bearing retainer nut (has 4 studs to fit the four holes and a 1/2 inch socket in the end) so I can torque things up instead of guessing with a punch and hammer. also got some ball type allen keys (sick of forcing the old ones) and hex sockets too.
Got all the tools out and it started to rain. Put everything in the garage and read my book until it stopped. Got all the tools out and it started to rain. Put everything in the garage and read my book until it stopped. Got all the tools out and it started to rain. Put everything in the garage and read my book until it stopped. Got all the tools out and it started to rain. Got pissed off and put everything away in the garage and gave up.
Have decided to just make do with the old rear brakes (might swap lwb rears on though) until I can geta "bolt on (or as damn near as) rear disk system". My 'A' frame (well the parts) the old man was making got biffed by some guys at his work (cleaning up for christmas) while he was on sick leave so I have to find another one before I can move the POS to get an exhaust made. So far this weekend sux, still have tomorrow (and the fact I am on leave for three weeks) to look forward to.
plans were simple - wire up front spots. 20 minute job max.
instead though me and moonhopper had a few bourbons and came up with a great plan to fit and wire up on-board-air and an electric fan on my scud. all went well til i realised i had bought the wrong wire, terminals and relays.
we got most of it done though through perserverance(sp) and lots of barrel 51 & export. ive now got fully functioning air pump and the electric fan just needs the right relay fitting - but it works!! pissed up wiring is bound to create fun times in the future me thinks
the spots are still in the box though
finaly made the front hooks to be in line with the chassis
Just fixed a diesel leak in my Bosch VE Injector Pump speed timer cover (pressure side). Pulled the cover off and found the o-ring has suffered serious erosion and pitting... is this an age thing, a fuel issue, or is the moreys fuel additive I use occasionally causing this?
~ Good roads lead to bad fishing. ~ Eric Wight, Maine Game Warden ~
Windsock wrote:Just fixed a diesel leak in my Bosch VE Injector Pump speed timer cover (pressure side). Pulled the cover off and found the o-ring has suffered serious erosion and pitting... is this an age thing, a fuel issue, or is the moreys fuel additive I use occasionally causing this?
you sure the o ring was not nicked /cut on assembly, any other o rings showing the same erosion?
pedro
pajeroboy wrote:well last night i whound my front torsion bars up to level it back out from when i lited it last year.slipped off the nut with th socket and powerbar and scored myself a bit ot a black eye oh well it was heading for my nose,would have broken it if i hadnt turned my head.
Did the same and got close to levelling out the front with the back, managed to avoid any broken noses and/or black eyes!
96 Wrangler Sport. 2"BB, 1.25"BL, Front discos, Adjustable rear trac bar, Cb and yet more to come! "Its a jeep thing"
Pedro wrote:Windsock wrote:Just fixed a diesel leak in my Bosch VE Injector Pump speed timer cover (pressure side). Pulled the cover off and found the o-ring has suffered serious erosion and pitting... is this an age thing, a fuel issue, or is the moreys fuel additive I use occasionally causing this?
pedro
Hi Pedro,
Thought that also when I first saw it. had a look at the o-ring seat, no problems there as it sits fully snugged against all flat surfaces with no moving parts apparently near enough. The cover is simply a flat plate with no macined seating surface, just flat. Can't quite see it in the photo (can if you magnify it on IE page zoom) but the seams of the o-ring have started eroding also. Could be a faulty o-ring but it is an older pump so it may have been faulty for a while but only started leaking badly now but I don't think so.
I am really hoping it isn't in any of the other o-rings in the injector pump - major issues if there are.
One reason why I ask about fuel issues and wondering if anyone else is having problems is I got caught out in the late 1995 bad petrol issue (imported from Malaysia) where there were too much aromatics (or some other crap) that ate o-rings in holdens and falcons carbys. Am hoping it is not a similar issue with some of the imported diesel.
some of the additives in modern diesels do eat o rings in some older diesels often all they need is just a replacement o ring pajero injector pumps often have 3 o rings that get eaten by modern diesel most people replace the top 2 and don't realise there is a third one. yorick had that issue on his paj injector pump and mentioned it to a mechanic mate of his and he said oh yeah they all do that
my 4wd is not a truck
mercutio wrote:some of the additives in modern diesels do eat o rings in some older diesels often all they need is just a replacement o ring pajero injector pumps often have 3 o rings that get eaten by modern diesel most people replace the top 2 and don't realise there is a third one. yorick had that issue on his paj injector pump and mentioned it to a mechanic mate of his and he said oh yeah they all do that
OK, cheers for that, I'll have to look at the schematic diagram again to count the seals and head to Autokraft tomorrow I think and get a seal kit. Injector Pump is on a 1986 engine and I don't know whether anything has been done to the IP in that time. Could be heading into big problems as if it has happened to this seal it may well have happened to the others.
bought this yesterday
best 200 bucks i ever spent and the nissan fits too..
WARNING:
taz01 wrote:bought this yesterday
does it steer i was browsing and did spot it but i couldn't see how the steering on it worked
leave the truck steering unlocked works great
WARNING:
Today helped Stinky fit the ....... to the front and rear ....
then helped Taz01 fit the cogs and leaver for the new ... .....
Good weekend really... now next weekend I need to sort out my steering, this fixing the 14 of a turn out
well i got my zuke transporter all braced up and made some ramp legs so the back end of the terrano doesnt lift up in the air. and started to cut and pollish the terrano after a bush trip that scratched the hell outa my shiney that i swore i wasnt going to take offroad but it had to happen i supose.
the top of the door has been cut n pollished but the bottom hasnt i think it has come up realy nicely.
go to ripco and get the coloured polish it helps
Must be a short Nissan
and we will continue this through to the nex weekend as for alot of us its holiday time, so every day is a saturday....
fixed my dodgy steering, adjusted steering box play, feels real good now, no play at all...
removed front bumper valance/skirt, as after me last trip out think it was the culprit for putting sum nasty cuts in my tires on the outa lugs.. gona get out the hammer and file and smooth out some of the sharp edges on the inner gaurds also,
just fitted x2 rated recovery hooks to the front of me truck, look good.
next on the cards, is
Purchase tubes for me tyres
buy new steering dampner and then get wheel alignment.
that should do for the holiday period
oh yea and, building rear platform for the back, as ive already ripped out back seats, gona build platform to sit on wheel archers, will be to serve many purposes, place to lay me head for me n the mrs over our xmas holiday travels, and will be enuf room for storage underneath, for the shit i dont wana see ie: spade, recovery gear etc, and the fishing rods too
- Steve_t647
Have a look at the seam that runs up the firewall in front of the driver and passenger, some gentle massaging (BFH) and you will have less rub issues
