FJ70 Fitting of a snorkel?
For all topics relating to Petrol engines and modificiations.
Kempy
Post by Kempy »
Howdy,
Im thinking of fabricating a snorkel up out of pressure rated plumbing pipe the only issue I face is that the stupid bloody air intake box does not lend itself to having any plastic conduit or other material attached to it due to a mounting bracket right in the way.
Does this make sense to other 70's owners? How can I get around this issue?
Any help appreciated.
Kempy
madaz068
Re: FJ70 Fitting of a snorkel?
Post by madaz068 »
Kempy wrote:Howdy,
Kempy
Can you take a pic and show us. Might be able to help
Bubba
Post by Bubba »
From memory,
Cut the existing intake off and weld a plate over it, then cut a 3 inch hole in that place you need it and weld on a 3 inch pipe, fit you flexi pipe over that, seal and you are done. Easy as
I did have to move my washer reservoir though but that’s not a biggy
Benjamin Franklin
rokhound
Post by rokhound »
If you can use a welder, grinder and rule, why not make one from steel tube instead?
They are a lot stronger and don't look like you have robbed the down pipes off your house.
This is one that I have just made up for my my 90 series (prado)
Used 1mtr of 3" tube, 1 3" 180degree mandrel bend, some flexy pipe (behind the gaurd) and a Donaldson air ram.
Whole thing owes me about $150, and a a whole heap of time as this one has lots of size and shape alterations once through the gaurd.
dazza85
Post by dazza85 »
rokhound wrote:If you can use a welder, grinder and rule, why not make one from steel tube instead?
Snip XXX
How have you mounted it to the pillar ??
any chance of a photo ?
What have you used around the pipe where it goes through the guard ?
Bubba
Post by Bubba »
I agree about the plumbing pipe, it looks, well, like plumbing pipe
Benjamin Franklin
Kempy
Post by Kempy »
Im going to go and mull this over some more,
Thanks for the help so far. Ill be back.
Kempy
