Should the oxygen sensor be water proofed where is connects below manifold??
Bubba wrote:It's not just a wet dizzy is it? Mine used to do it all the time. It dosen't take much water to get it wet either
Dutch89 wrote:May have to go see the sparkey again, its been in 3 times to find out what is causing the stall, engine recovers when i push the clutch in and then goes fine, even after the bog gets deeper. Mainly seems to be the initial stage of entry that it hates.
