Surf rear bar
Mattman
Surf rear bar
Post by Mattman »
Does anyone make these in Wellington?
I would like to replace the factory rear bumper with a custom unit that could handle a high lift jack and possible a spare wheel mount as well.
Matt.
SupraLux
Complete Bastard
Post by SupraLux »
Making one in the coming week in Christchurch... close enough? I'll post a photo when I have it made. Nothing too flash, just some solid barwork around the ass-end of the Surf with a recovery point somewhere.
Still designing it, but should have it built by next weekend. Will build three, one for Conans Surf, one for mine and a spare.
Hadn't thought about a tyre carrier for this one, but will give it some consideration. Do you want to keep your towbar (assuming you have one?) or integrate a 50mm receiver into it?
Steve
Mattman
Post by Mattman »
Hi Steve.
Do you have any guestimate on price?
A 50mm receiver would be cool.
Has anyone fitted a later model surf/hilux swing away wheel carrier to any earlier surf? Looks like the rear mounts might be close enough.
Matt.
JTop
Post by JTop »
The supports are not in the body for the carrier, you have to fit support plates inside to stop the carrier tearing off.
J Top
Mattman
Post by Mattman »
Are the supports removable or would these need to be made?
Matt.
JTop
Post by JTop »
you need to make up plates to spread the load
J Top
Mattman
Post by Mattman »
I am tossing up with trying to retro fit a later model Surf wheel carrier or get a rear bar made with a wheel carrier on it.
Getting curved supports inside the body might be difficult.
Matt.
krawlr
Post by krawlr »
is youre surf the early model ?
SupraLux
Complete Bastard
Post by SupraLux »
Go bar-mounted... the truck mounted ones don't like it when you drop off a bank and catch the spare wheel on something :) They're not built that strong.
No idea of price at this point... will have a better idea later in the week.
Steve
Mattman
Post by Mattman »
Yep it's an 88 Surf.
Cheers Steve.
Matt.
Macca
Post by Macca »
How would you get on with a 50mm reciver as a tow bar? or does this become illegal? have been told it could only be used for 4wding and not as a removable hitch TOW BAR. But i think it would be stronger than a lot of towbars out there due to the size of the surrounding steel and larger cross bar. What is your opinion supralux?
SupraLux
Complete Bastard
Post by SupraLux »
My 'opinion' means sweet f$%& all :lol: but the law states (or stated last time I checked, any other takes on this?) if your vehicle has a COF then a tow hitch must be done by a certified towbar place, like blackwells.
If it has a WOF, then you can pretty much duct-tape a piece of 3mm plate with a tennis ball glued on the end and call it a towbar.
If I'm making something to go on the back of a vehicle for towing purposes I would build the bar piece by piece, tack it all together and give it to blackwells to weld up and rate... two advantages: 1, it will get a load rating tag and 2, that tag will mean no-one will ever question it. WOF or COF.
Steve
Return to “Toyota”
