Put the lifted springs in the Rangie on Sunday, sat about 60mm higher all round which is all good. More research will be done in shocks and shock mounts to get the most out of the droop available as with extending the brake lines.
Not so much a problem yet, but there is slight vibration at different speeds/loads. I didnt bother with castor correction bushes as I didnt want any more angle in the front driveshaft and Ive found that the wandering is very minimal. Did anyone do anything about it that had these symptoms?? I can live with it at the moment but Im guessing the UJ at the transfer box end of the front driveshaft will flog out quicker if left.
Ive heard of people using Series 2 Disco front driveshafts as they have the double cardon joint in them, but of course they want top dollar for them.
Anyone have any thoughts??
Rex
