Hilux/surf Gearbox
mylux
Shockless
Hilux/surf Gearbox
Post by mylux »
Hi all,
Bit of a problem :( :( :(
will a 5 speed gearbox out of a 88 surf(2l 2.4 Litre) fit a doublecab hilux(3l 2.8 litre)?
do you need to modify any thing?
will the electrics hook up?
Thanks in advance
Richard.
Bulletproof
Re: Hilux/surf Gearbox
Post by Bulletproof »
mylux wrote:Hi all,
Thanks in advance
Richard.
I have an 87 hilux for parts that has a Surf gearbox fitted.
Completely different gearbox .The gear-levers are in a different place and they are lighter than a hilux box. 5th gear very weak. I personally would not go there.
Cheers Richard
Never say die, up man and try
MATT4U
Post by MATT4U »
Bulletproof wrote:
mylux wrote:Hi all,
Thanks in advance
Richard.
Cheers Richard
depends which surf greabox, if its a G52 don't bother, If its the W56 (out of the 80"s IFS surf) then its the good one.
HoweverIt also depends what year your double cab is, is it beam or IFS e.t.c
mylux
Shockless
Post by mylux »
Hi,Thanks for the info.
The doublecab is a 93 beam front end.
I have two surfs that i can rob off,one is beam front,one is ifs
Where would you look for the numbers ?
Smurf
Post by Smurf »
Beam axle surf LN/YN60 should have a g52 box, LN/YN61IFS Surf should have a W56.
mylux
Shockless
Post by mylux »
Smurf wrote:Beam axle surf LN/YN60 should have a g52 box, LN/YN61IFS Surf should have a W56.
so the "w56"will bolt straight in?
Are the gear leavers in the same place?
Any other mods required?
Thanks
tgaguy1
Post by tgaguy1 »
mylux wrote:Where would you look for the numbers ?
On the manufacturers data tag in the engine bay, the transmission code will tell you.
Smurf
Post by Smurf »
You can swap G52 for W56, they bolt up but the transfer lever is further back on W56. To swap from G52 to W56 you need to move the hole in transmission tunnel back by approx 60-80mm, So your rubber boot won't fit unless you patch the front of the hole to match.
Would pay for you to check your hilux and see what box it has.
Will tell you on id tag under bonnet on firewall. G52, W56, R150 possibly
mylux
Shockless
Post by mylux »
Thanks guys.All fixed now, we went with a recoed gearbox from lineside. :D :D :D :D
Thought the surf box might be more hassle than its worth, :roll: :roll: :roll: :roll:
Return to “Toyota”
