Aisin Free Wheeling hub parts?
nstacey
Post by nstacey »
I removed my FWH's from my hilux in order to clean them up and re seal them as one had worked its way loose. In the process I seem to have stretched one of the springs, the one that goes behind the clutch. Is it possible to get replacement parts new for these hubs? where from? Here's a pic of the difference. I do have an AVM spare I'll use in the meantime, but the Aisin ones are definitely a preferance.
Thanks
Nick
85 Hilux single cab
02 Grand Vitara
wjw
Re: Aisin Free Wheeling hub parts?
Post by wjw »
You'll need to go to a wrecker, Toymotor don't sell much in the way of parts for those. About the only thing you can buy seperately is the nuts, bolts and cone washers
Who knew Prados could fly?
NJV6
Post by NJV6 »
Is that stretched spring from one side and the other the other side?
On mine there are two springs in each side and one of the two looks like the 'stretched' one and the other like the normal one.
SIg might have a spare spring if you ask him nicely (he's got everything else :D )
nstacey
Post by nstacey »
NJV6 wrote:Is that stretched spring from one side and the other the other side?
Yea, the springs are from the 2 different hubs, the one thats broken and the one thats not.
85 Hilux single cab
02 Grand Vitara
GotFlex
Post by GotFlex »
post ur model and frame, im in toyota parts
nstacey
Post by nstacey »
Its an LN65. I bought the hubs 2nd hand though, but they are whats fitted to the beam axle lux's from factory.
85 Hilux single cab
02 Grand Vitara
nstacey
Post by nstacey »
Solved this problem with a trip to pick a part
FYI, Aisin hubs on a late 80s/early 90s Isuzu bighorn have the same smaller spring (as pictured above) as the Hilux ones.
85 Hilux single cab
02 Grand Vitara
oldblue
Post by oldblue »
They have the same spring in Toyota electric hubs, if your stuck, I'll sort you out with a good one ( from my spares )
Return to “Tool Shed”
