rocker arm failure
TC
Stropper
rocker arm failure
Post by TC »
hi does anyone have any ideas on why a rocker arm would break?
i had timing belt and cam belt done about 300kms ago since then blowing lots of black smoke on acceleration and gutless as.
SMOKEY
Re: rocker arm failure
Post by SMOKEY »
Sounds to me as If the cam timing has been set incorrectly and the pistons have hit the valves. The 2.5 mitzys are designed so that the rockers/pedestals break when this happens. If you payed to have the timing belt done take it back.
FITZY.
Heath
Post by Heath »
SMOKEY wrote:Sounds to me as If the cam timing has been set incorrectly and the pistons have hit the valves. The 2.5 mitzys are designed so that the rockers/pedestals break when this happens. If you payed to have the timing belt done take it back.
FITZY.
X2 Some one screwed up.
Return to “Mitsubishi”
